    Junior Member Two Rings Huluis's Avatar
    Jul 14 2020
    Graz
    BMS Turbo Double Baffle Oil Catch Can question
    Does anyone of you have this Catch Can installed.I installed it over a year ago and have not even a drop of oil in it.My Audi A5 2.0 tfsi,i had before with the APR Catch Can,there was always oil in it.Btw.i have an Audi S3 8V.
    regards Tom
    It's an Oldschool Hybrid,burns Gasoline and Rubber.
    Veteran Member Three Rings Eli0073's Avatar
    Jul 17 2020
    USA And Finland
    You still have the OEM PCV plate. That's why. It's doing it's job. Unless you start pushing the car very hard on corners that catch can will stay bone dry. No need to worry.
    Sent from my IN2017 using Audizine Forum mobile app
    Dec 25 2004
    Earth
    Being totally unfamiliar with the BMS catch can I went to their website to see what it looks like...
    Hmmm...
    Issues...could be not connected right? Or leaking?
    I see on top on the BMS can there is the words "IN" & "OUT" are the hoses hooked up correctly?
    The 4 holes ontop...is it vented to atmosphere?
    Since it doesn't replace the oil separator/pvc with a plate...
    Maybe the OE plastic oil separator/pvc is bad? As its not venting any oil fumes?
    What year is your S3? Other mods? Stage tunes? Higher boost can often damage the OE plastic PVC...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jul 14 2020
    Graz
    [QUOTE=
    [/QUOTE]
    The holes are threads for the holder,i have an S3 from 2014,the Engine has around 25.000 miles on it,Stage 1.
    - - - Updated - - -
    Jul 14 2020
    Graz
    @Eli0073
    Alright,thank you.
