Results 1 to 4 of 4
    Junior Member One Ring zebuckley24's Avatar
    Jul 04 2021
    Frisco, TX
    A7 RS4 style wheels for my B8.5 S5
    I’m looking at a set of 20” RS 4 wheels off of a 2014 A7 to put on my S5. Wheels are 20x9 and I know they will fit, my only worry is offset as the offset of the wheel I’m pretty sure is 37mm. I don’t have spacers yet, but would they look terrible without spacers or should I wait for spacers to put them on? Also what size spacers should I get?
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    37 will be a bit tucked. I have a set of ET 40 wheels I use on my 14 S5 and I use 20/25 spacers
    Jul 04 2021
    Frisco, TX
    Quote Originally Posted by Neil F View Post
    How close is the fit? I’m wondering if I go 20/25, 17/20 or 15/20 with 37.
    Jan 13 2017
    marlton/nj/usa
    Quote Originally Posted by zebuckley24 View Post
    They fit fine. Keep in mind mm to inches. 5 mm = 0.19685" 2/10 th inch. Splitting hairs I am running oversize 275/35/19 tires and am lowered. Push them out IMHO. I also wanted H&R DRA bolt on spacers as opposed to thich spacers with longer bolts. Bolt on spacers are a lot easier to deal with when changing tiers, (which I do twice a year, plus the occasional flat and maintenance). It is harder to set the spacer on the hub, bglance the tire on it and get the lugs lined up. DRA spacers are only available in 20mm and up
    2014 Estoril blue Cab Chestnut brown interior
