Results 1 to 6 of 6
    Mar 20 2018
    Upstate NY
    Front License Plate Mount - How is it attached?
    I can't see where one would drill into on an RS grill to secure the OEM mount, so I'm hoping there's a way to secure it that doesn't cause permanent damage ???
    Hoping that if I buy a used RS5 with a mount installed, that I don't have to buy a replacement grille.
    Apr 19 2019
    Toronto, Canada
    Quote Originally Posted by NYAUDIS4 View Post
    Unfortunately, it's screwed right into the grill. If you took it off, the grill would have pilot holes drilled in it.
    Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
    Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
    Apr 05 2012
    Earth
    I can't speak for the B9.5 cars, but for the B9, there are two threaded holes in the front bumper that you can use to screw in the license plate holder. You would use regular machine screws, not self-tapping screws. On my early build B9 the threaded inserts are painted black. I think on later ones they're unpainted brass.
    Mar 20 2018
    Upstate NY
    Thanks both...the threaded screw holes are in the crash bar behind the mesh, I assume? I think I see them in pictures - I'd thought those were sensors, and wondered how the mount in front was not an issue.
    Apr 05 2012
    Earth
    There are parking sensors in the grill. The threaded holes in my B9 are in the center of the crash bar in the solid portion of the grill. Looking at the car dead on you can see them.
    edit - Here's a picture of someone else's front bumper where you can see the mounting holes. On this one it looks like they're plastic inserts that would need a self-tapping screw. Maybe that was done on later builds as a cost cutting measure instead of the threaded brass inserts. Click on the image to enlarge it.
    Mar 20 2018
    Upstate NY
    Quote Originally Posted by JohnEnglish View Post
    Thanks! Those look like they could be dremeled out.
