Results 1 to 8 of 8
    Nov 22 2022
    Denmark
    Rotor wheels 20 in ET 26
    Hi All, looking to run 20 in ET 26 Rotor wheels , with standard suspension, any feed back if this is possible Will be much appreciated.
    Rgds Tom
    Dec 29 2017
    Phoenix, AZ
    Assuming this is on an A4 or A4 avant.
    Not on stock suspension, you'll kill your fenders.
    Can be done with adjustable arms, though.
    Check the wheel fitment thread.
    Now if you're in an Allroad you're golden. Slap them on.
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    2010 Avant // 2015 Allroad
    Nov 22 2022
    Denmark
    Yes , A4 B8
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by TomRas View Post
    Rgds Tom
    It’s possible, especially on stock suspension, but it’s a very aggressive fitment, maybe even an ever so slight poke, choose you tires wisely.
    A better all around fitment, although still aggressive, would be the 19x9” et33.
    Veteran Member Three Rings Dr.B6Banter's Avatar
    Sep 26 2017
    B6 A4 1.8T, B8.5 SQ5
    NB, Canada
    You'd have to run pretty stretched tires to not have the tire sidewall ruin your fenders/ fender lines.
    I have A6 rotors (20x8.5 et45) as my summer wheel setup with 12/15mm spacers which sit a few mm sunk which is enough to be low without instantly destroying fenders/ liners.
    Like others have said et35-30 is the sweet spot for a4 with the allroad having wider arches to fit something like et26
    B6 A4 1.8T Nottro 02X 6spd Conversion | GTRS | IE Forged Rods | Suspension/ Subframe Poly Bushings | 18z BBK Front & Back
    B8.5 SQ5 3.0t | JHM 207mm Crank Pulley | IE Dual Pulley Tune & ZF8 TCU Tune | CTS Test Pipes, Downpipes & HX | AWE Touring Exhaust
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by k.sigota View Post
    This is excellent. I just bought ‘16 Allroad and immediately wanted these rotors.
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by Ford Prefect View Post
    DM’d
    Dec 29 2017
    Phoenix, AZ
    https://discord.gg/Q48dceAW
