Results 1 to 8 of 8
Thread: B5 S4 Stage3
    Oct 10 2013
    B5 S4 Stage3
    Stage 3 2001.5 Audi S4, 6 Speed Manual. 4th Owner. Clean title. Accident free. All work, modifications between 100K+- and now 106,555. Miles will go up slowly, as I still enjoy the car. Car needs nothing at the moment. All work done in the photos, i am sure i missed something. $15,600 (Enkeis and 17” Avus Spare Set), $14,600 (On 17” Avus). Full Folder of receipts, starting with the New Car Order from February 20th, 2002. First child on the way, and a very busy job. Lets not waste each other’s time.
    PERFORMANCE/MAINTENANCE
    BW K04s
    ER SMICs
    Walbro 450 Fuel Pump
    710N Diverter Valves
    Bosch EV14 Injectors
    034 Turbo Inlets
    034 Lobster Claws
    034 85MM Hitachi MAF Housing
    034 Snub Mount
    034 Trans Mount
    034 Carbon Fiber Intake
    2.0T Coil Conversion
    3Bar Map Sensor
    Ringer Racing Stage 4+ Clutch and Flywheel
    AEM Wideband Kit
    XS Power Catless Down Pipes (vbanded)
    XS Power exhaust (vbanded)
    JHM Short Shifter
    Full Timing Belt Service
    Cam Caps
    Cam Seals
    Cam Adjusters
    Coolant tank + Flush
    AUX Waterpump
    Intake Manifold Gaskets
    Valve Cover Gaskets
    Waterpump
    Thermostat
    Fuel Sensor/ Sender
    GET Tuned (Brad Watkins)
    SUSPENSION/WHEELS
    KW V1 Coilovers
    034 Full Front Control Arm Kit
    Stud Conversion
    Rear Upper Strut Mounts
    Brakes/ Rotors + Flush
    EXTERIOR
    OEM RS4 Grille
    Aftermarket “RS4” Bumper Grilles
    OEM Euro Valeos
    Sport Mirror Caps
    18” Enkei RPF1s + Michellin Pilot SS
    INTERIOR
    Corbeau Sport Line RRS Seats
    Wedge Seat Brackets
    JHM Weighted Shift Knob
    Project B5 “RS4” Door Handles
    Painted “Piano Black” Wood Trim
    Blue Tooth Adapter
    Sent from my iPhone using Tapatalk Pro
    Senior Member Two Rings Quattro 13's Avatar
    Sep 01 2013
    B4 90Q, C4 UrS6, B5 S4 (x2),'72 2002
    Buffalo, NY
    Bump for a very fair price on a clean, low-mile, Stage 3 S4, from a standup seller!
    I bought an exhaust system off of OP a few months ago and he was a pleasure to do business with. I got a glimpse of the car at that time, and it looked as good as it does in these photos.
    Really clean build, man. It's disappointing to see you move on from the platform, but hopefully someone on here will give it a good home moving forward. Good luck with the sale!
    Oct 10 2013
    Quote Originally Posted by Quattro 13 View Post
    I really appreciate that. You are def a trooper for making the trip out here! Thanks again, hope all is well.
    Established Member Two Rings JLXPro's Avatar
    Aug 03 2009
    2008 Yamaha WR250x
    Sedona, AZ
    Give me a call. 928.300.0758
    Looking.......
    ________________________________
    Sold "Sylvia" 2000 Nogaro b5 S4 AWE STAGE III
    Sold "Susan" 2005 B6 S4 Stage +
    Oct 10 2013
    Bump with full description
    Oct 10 2013
    Post Holiday Bump.
    Oct 10 2013
    Deposit acquired. Pending Sale.
    Oct 10 2013
    Sold
