Results 1 to 3 of 3
    Apr 22 2021
    san diego/ ca
    back end feels loose and sways like crazy over bumps
    at speeds above 40mpg, when i hit a bump in the rear with one wheel (for instance, a manhole cover in the road that drops down a bit) my back end seems to sway way too much, it feels uneasy. I havent had time to get it in the air and look at it but what could cause this feeling, end links loose or different lengths?
    also, separate issue. Buddy was behind, said one of rear wheels looks like its whoobling, looked at it in the mirror when driving and it defintiely does whooble, question is could that be from the spacers and the wheel being put on with the spacer not centered or is this a bent wheel issue? I barely drive my car so i would have remember hitting a hole so hard that it could have bent my wheel, and i had them rebalanced a month ago and the shop would have seen the wheel not being straight i assume.
    2018 Audi A4 P+ Quattro Mythos Black
    AWE CAI | ECS turbo-back valved-exhaust | ECS strut brace | ECS FMIC+Charge pipes | 034 dynamic+ springs/RSB+end links/Trans Mount/FSB end links | GFB DV+| BlendMount+EscortMax 360 | RS4 grill+fog vents | Dynamic mirror signals | IE S2 ECU | Bilstein B8 Sport Shocks | CBF splitter/diffuser/mirror caps/trunk lip | WINTER--STOCK 18's--BFG G-FORCE COMP2 A/S+ | SUMMER--IWAutomotive FFP1 19X9.5--Michelin PS4S
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    If this has started after you had the wheels rebalanced, it may be the wheel wasn't remounted on your spacer correctly - that should be a very easy thing to check.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Apr 22 2021
    san diego/ ca
    It was doing that before the rebalance, a diff friend did ttell me my wheel was wobbling before and i totally forgot to check it but ill check it out ans see, but the wheel wobbles ( side to side ) so just to my limited understanding a not centered spacer would cause a side to side wobble, also it seems unlikely that it would cause my rear end to feel really loose and unstable, plus is that possible if they are hub centric spacers? Im not sure but i wasn't thinking of the spacer because their hub centric.
