Hi guys, I'm in the process of putting new door speakers in, I got factory speakers from the junkyard and will cut them out to use the housings to have a factory mount and use of the harness. I just want a little bit of bass to enjoy music and found on another forum the Pioneer TS-W260D4 sub is a free air sub which will be ideal for where I want to mount it. if I want to install a subwoofer in place of the 8" factory sub on the back shelf of my audi a4 do I need a separate Amp or will the factory Amp be enough to power this sub?
If I have to add an Amp, can someone explain how to wire it in? Do I use the power from the harness going into the original sub and put that into the Amp for line in and use speaker wire to go from the Amp to the sub? Will it work like the factory sub then? Or do I still need a remote wire? Power and ground are easy since the battery is right there.
I have a non B&O system with nav and the full mmi, but I'm sure I have an Amp still in the trunk.
Sorry I'm new to audio upgrades this complicated
Sent from my SM-G986W using Tapatalk
