Afternoon all, I have a 2016 S3 with an 034 motorsports stage 1 ECU and TCU tune. More recently I was driving a bit more aggressively than normal and I found that if I hit WOT in a higher gear (5th or 6th) under 2k RPM, once I hit boost the steering wheel would vibrate at around 2500 RPM, very briefly albeit. It doesn't seem to be wheel speed dependant, it does the same thing in lower gears under similar circumstances, is this normal given the higher boost from the tune? It doesn't vibrate at all past ~2600 RPM so a very narrow window but it feels as if something is out of balance. The car is completely stock, no suspension work or anything notable. I am running continental 255 35 R19's but it doesn't seem to be wheel speed based anyway. Car has been well maintained since my ownership, oil change at 5k on the dot, DSG service less than 10k previously and haldex within 10k as well.
