    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    B5 RS4 door handles, Work CR kai wheels, CH ecu, ABS, ESP Module, socal
    Items for sale are located in Socal. Buyer pays shipping costs.
    OEM B5 RS4 interior door handles, never installed. - $150
    Work CR Kai wheels, 18x8.5 et+37, 5x112 - professionally redrilled from 114 to 112 with pressed in steel inserts, tires Hankook V12 evo 2, 235/40/18 - with life. Wheels are free bends, no rash, some normal wear, no cracks, no repairs. - $1000
    ECU from 2001.5 B5 A4 1.8T, ABS and ESP module, APR stg 3+ on ECU - $100 each
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Sep 24 2022
    Colorado Springs, CO
    Are the door handles still available?
    Veteran Member Three Rings Tec_Nine's Avatar
    Sep 17 2012
    Riverside, IL
    Sent you a pm
    Veteran Member Three Rings B5_Booster's Avatar
    Mar 30 2018
    Black B5 S4 Stage 3 Sedan, B5 RS4 Conversion Car
    Planet Earth
    Quote Originally Posted by RStadj View Post
    He sold all of these parts last year
    01.5 Nogaro Avant Stage3 GIAC e85
    Sep 17 2012
    Riverside, IL
    That makes sense, thanks.
