    Nov 22 2017
    Elk grove, ca
    Mmi hard drive failure
    Is there a way to get the files from a working drive to use to clone mine or am I stuck with getting one from the dealer?
    2014 S6
    Roc Euro intake
    RS7 inlets
    Pinnacle Performance RS7+ turbos
    MERC heat exchanger w/cwa100
    SRM LPFL w/ethanol sensor
    DS1
    Leistune ECU/TCU
    Current PB [email protected]
    Mar 07 2020
    Minnesota
    Back in my bmw days it was common to clone the i-drive spinnings to ssd's for backups, speed an reliability, but this would need to be done prior to failure. We used clonezilla software for cloning, and had to source the now-obsolete PATA drives.
    Do you know which interface, size and form factor the drives uses? If you also know the file structures (ntfs, etx4, fat32) etc you could resize to gain more space.
    Nov 22 2017
    Elk grove, ca
    It's a normal 3.5 spin up drive. You can here the head clicking.
    2014 S6
    Roc Euro intake
    RS7 inlets
    DS1
    Leistune ECU/TCU
    Jan 18 2022
    2015 A4 Prem. Plus, 1987 Scirocco 16V
    Raleigh, NC
    I think you can just replace the drive with an SSD but as Norskie mentioned you would need to clone a working one I believe. The A4 forums mentioned replacing the drive somewhere but I cant seem to find the thread. DrGER would be a good resource to message or Smac. They are some of the more technical people that I've seen.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
