I recently bought a 2018 RS5 coupe. Traded in my heavily modded B8 S4 and wanted something I could enjoy stock (although I’m already looking out for Black Friday stage 1 deals lol). I’ve only driven the car about 400 miles but enjoying it so far.
I do my own maintenance. I’m right at 50k miles so was researching common issues and looking for DIY’s. Definitely much less out there compared to the B8 forums and the B9 S5 group isn’t too much better. But alas. Replaced the rotors and pads, added a new intake and did my first oil change. Even coming from a B8 S4 I was surprised how tight the engine compartment is packed. There isn’t even enough room to change the belts without, I’m guessing, going into service position.
I have a few issues/questions on a few things I couldn’t find answers to…
1. I have the speaker rattle coming from the rear drivers side when there is too much bass on a song. I’ve heard there was a tsb or recall at some point where they’re adding some additional padding or tightening the speaker brackets or something? Has anyone fixed this themselves? Any tips before I start messing with it?
2. The headlight washer on the drivers side seems to be leaking. Within the first few days of driving I got a low washer fluid message. Added a gallon of fluid and thought it was good to go. A few days later, message came up again. Added another gallon. Thought maybe it had a giant reservoir? Nope lol. A few days later the same message again. Now that I have been paying attention, there is definitely a small puddle on that corner on the ground after driving around. I’m guessing the hose connected to the sprayer is leaking but haven’t had time yet to pull off the wheel and pull back the fender liner to see if I can access the washer. I plan to turn off the stupid thing with vcds but still need to sort out the leak. Curious if anyone else has experienced this?
3. I noticed now that it’s cold out, when in D mode the exhaust only comes out of the drivers side muffler. Cold starts and just driving around or idling it’s clear only the one side has exhaust coming out. If I switch to S then suddenly both are open. It’s a little annoying. I guess this isn’t really an issue but people driving behind me and seeing I have dual exhaust with gases only coming from one side probably think I’m an up badger or something lol. Doesn’t appear to be an actual issue but curious if it is in fact normal?
4. Changing belts. Now that it’s cold I’m noticing a bit of belt squeal when I first start the car. Bought some belt conditioner in the hopes I can get rid of the noise on the first startup of the day until I change the belts. Guessing it’s the drive belt so was going to start there but again zero room in there to change it. Do I need to go into service position or has anyone been able to do it without pulling the front end apart?
5. Black Friday 034 stage 1? I only see 034 and APR tunes for this model. Definitely want to go with flash at home so 034 looks to be my choice?
Thanks in advance for any input!
