Results 1 to 2 of 2
    Junior Member Two Rings
    Mar 13 2015
    Midwest
    Front Mag-ride suspension replacement
    The 2 front magride struts need replacement along with the sway bar links on my 2016 TTS with around 80k miles. Any advice from others that have had the same issue? Assuming I should replace the strut mounts and bearing too.
    Senior Member Two Rings TwistRate's Avatar
    Jul 22 2018
    Twin Cities
    I'd replace the entire shock and mount. Might be a good time to entertain lowering springs if you haven't done so.
