Results 1 to 6 of 6
    Nov 18 2022
    Wesley Chapel, FL
    Uneven Tread Wear on front tires fix?
    Does anyone have a fix for uneven tire wear on the front tires? The inside tread is wearing fast due to camber, what route should I go to fix that? I've heard upper control arms, and putting the alignment toe to zero, anyone have experience fixing this issue? Thank you.
    Oct 09 2008
    The reason is worn suspension components or bad alignment, or a combination of the two. The fix is to replace any worn components and have an alignment done. By this point all of the control arms probably need to be replaced.
    The Awesome™
    Senior Member Four Rings
    Jun 08 2021
    PA
    On any of these cars its best to just do all the control arm at once. They are all getting older now. Worn uppers will let the top off the wheel lean in. Worn lowers will let the bottom come outward. Most likely with age its a combination of both. If its lowered then you may need to look into adjustable uppers.
    In extreme cases it can be ball joints or wheel bearings too. Ball joints all get replaced with a control arm kit.
    Nov 18 2022
    Wesley Chapel, FL
    Thank you!
    Jan 04 2021
    BMW x3 28i/ CBR F4i/ YZ125
    CALI
    Redid control arms/bushing lowers and solved inside wear drastically
    Senior Member Three Rings Slvrbul8's Avatar
    Apr 14 2021
    300zxTT and E46 BMW 330i
    Roanoke, Va
    Quote Originally Posted by _1SlowS4 View Post
    Curious what mileage you are at?
    IE Stage 2 Dual Pulley, APR HX, APR 187 and 57mm pulleys, Milltek Resonated Exhaust, Deval CF Diffuser, 034 Lowering Springs, 034 Rear Sway Bar, Eurocode AK.
