I picked up a B7 RS4 clutch kit and had a clutch master billet flywheel sent to CM in hopes they could resurface and mod it for a B7 PP. Unfortunately they didn’t feel comfortable with taking that much material off so I had them resurface it for a B5.
Before I sell the CM FW and buy a TTV FW setup for a B7 PP I’d like to try and use what I have.
From my research modding the flywheel only requires addressing the Dowel pins and stack height difference. I saw some guys had to grind their clutch disc to clear the FW but that seems like a none issue with the CM FW.
So only 2 things to address, the dowel pins seem easy since I could slowly drill out the PP holes until they were just large enough to fit.
For the 2mm stack height I’ve read multiple people say they use a precision washer to space the PP out the 2mm without issue and make sure SAC movement is correct but that seem kinda sketchy to me.
Has anyone used a washer long term that can confirm its fine to do?
Anything else im missing to make this work?
Thanks PJ
