Has anyone had an issue with one of the pipes (right from rear) touching the cross frame covering it? Located mid section. If so, what was your remedy? Everything else has been inspected, adjusted, and tightened.
Had a pretty bad rattle so wedged a piece of rubber between the pipe and subframe and the noise is gone, but the vibrations are still highly noticeable when shifting into lower gears. I do know that a lot will be expected with the upgrade but this is unusual.
