Results 1 to 14 of 14
Thread: AJL engine code
    Established Member Two Rings CliffA4's Avatar
    Nov 16 2022
    Blenheim, QLD, Australia
    AJL engine code
    Hi there, just wondering if there is an engine code that is similar or the same as AJL? I have the Australian AJL 180hp 1.8t and whenever I enquire about performance parts for it no one stocks anything. It has the external water pump.
    Thankyou.
    Sent from my SM-T290 using Audizine Forum mobile app
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    Yes its a 058 180PS DBC engine. Highest HP output of the 1.8T in a longitudinal application in the B5 in RDW market.
    The only main difference is the head part number(and associations) and higher mapping in ECU software.
    Nov 16 2022
    So if I look for DBC parts instead of AJL I'll find the parts I need that will fit?
    What about ECU software upgrades? Same?
    Thankyou.
    Mar 15 2018
    Europe
    Quote Originally Posted by CliffA4 View Post
    Thankyou.
    Certain parts might be specific but thats down to the 'upgrades' vs other types, what exactly are you looking for?
    Nov 16 2022
    Quote Originally Posted by Blazius View Post
    Mainly software for the ECU at this stage.
    Nov 16 2022
    I'm also looking for a code reader/ scan tool, every one i look up doesn't support AJL.
    Feb 23 2022
    Montenegro
    Delphi does bro
    Послато са SM-G960F помоћу Тапатока
    Nov 16 2022
    Quote Originally Posted by bajo_01 View Post
    Delphi does bro
    I had a look at their website but can't find actual products or prices. Do they make a handheld or Bluetooth scanner? I don't use laptops or pc.
    Mar 15 2018
    Europe
    VCDS for VAG. Delphi the one hes likely reffering to is an universal scanner, its aight.
    Nov 16 2022
    Okay thankyou, the website just sent me around in circles and wouldn't show the products prices etc.
    I'm just after a hand held unit to read and clear codes.
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    From my (limited) looking, OBDEleven should work for you. You may now get all of the fancy gizmos and gadgets and live data, but you should be able to read and delete codes just fine.
    VCDS will always be your best bet. If you plan on spending any length of time with this car, it’s likely worth it to get a cheap Windows laptop and generic VCDS cable.
    Sent from my iPhone using Tapatalk Pro
    Nov 16 2022
    Quote Originally Posted by RallyeBourne View Post
    Thanks, I was looking at a Bluetooth OBDEleven last night from a UK store but the in app purchases put me off. I've spent almost 10k on the car already so I plan on keeping it, investing in a laptop sounds like the go. Would you recommend Ross tech for laptop use or something else?
    Sep 10 2013
    The In-App purchases really isn’t relevant for those of us with older vehicles. You do NOT need to purchase any credits for basic read/delete functionality. It allows for super easy recording for newer vehicles for things such as changing the lighting characteristics, how many blinks for the lane change blinkers, etc. but I don’t think there even are any built in to the app for the B5. At least not for my ‘98.
    Nov 16 2022
    Ah okay then sweet, love my 23 year old car.
    Thanks for that link it works great, the previous owner sure did tick a lot of boxes when she ordered the car haha.
