Results 1 to 4 of 4
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Draining Iroz Catch Can
    So I tried draining my oil catch can for the first time today since I figured I’d have oil after being on built motor stage 2 for 1200 miles give or take. I removed the one screw holding it in place and attached a rubber hose. However, when I opened up the release valve the oil didn’t come out through the hose but rather through the center of the valve screw from what I can tell. The amount of oil was minuscule, I would say less than an ounce came out. Something seems off so I’m looking for pointers. TIA!
    Jan 06 2018
    Chicago
    Not much oil comes out in 1200 miles, sounds normal. The oil came out of the valve screw?
    Jun 11 2012
    Corona, CA
    Quote Originally Posted by Aj652 View Post
    Oh man, saw this on Thanksgiving and wanted to get a picture for you and completely forgot to reply. But yeah, if you look in this picture:
    You can see a hole in the center and that’s where the oil came out.
    Senior Member Three Rings 8STTRS's Avatar
    Jul 28 2021
    Navarre, Florida
    Yeah. That's fairly normal as far as the amount is concerned. I was a bit concerned about how little came out of mine considering the massive amount of white smoke coming from my exhaust after I get off the throttle after a pull. But, it turned out to be something that looks a lot like eggnog coming out of my catch can. It's a mixture of E and my oil, which I was reassured is normal for these cars. However, only maybe 2-3 ounces came out.
    However, I didn't have any leakage around my hose. I would doublecheck that the fitting is on there good and if so, maybe put a small clamp around the drain hose. But it would seem really odd for it to come out through the center. That would mean the valve seal itself is bad and you'd have to replace that.
    2018 Audi TT RS
    JDY Next Gen 6670 coming soon (shooting for 975-1kwhp on low boost).
