Results 1 to 6 of 6
    Junior Member One Ring
    Jul 19 2022
    Colfax CA
    AEB engine swap questions
    So I have a 2004 Infiniti G35 sitting at my house that I’ve converted from auto to manual and I have a good AEB that I was planning on using for my A4 Quattro but decided that the car needed to much so I parted ways with her. Now my questions are: is running a standalone Ecu required if I wanted to put the AEB in my G35? I know this isn’t a Infiniti forum so I don’t expect you guys to know much info about those chassis, but could I turn the stock AEB wiring harness into a standalone and run the stock Ecu in a different chassis such as this? I’ve tried using google and the closest I’ve came is the AEB to AWM wiring harness swap. Any info or links are appreciated
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    A lot of wiring work to be done. About 10yrs ago a programmer for C2 Tuning wired his built E30 BMW to run off an Audi/VW ecu, so anything is possible. Going with a standalone would be a much better start with a new harness. I recently bought a new harness to run with my MaxxEcu standalone for my A4 with an AEB, but I can easily pull it out and wire it up to run a 6cyl or 8cyl vehicle.
    1998.5 A4 1.8TQM My Build
    Jul 19 2022
    Colfax CA
    Quote Originally Posted by xdewaynex View Post
    I seen maxxecus kit for the aeb, did it come with a starting point to begin tuning with?
    - - - Updated - - -
    This ? https://www.maxxecu.com/products/pluginecu/audi_a4
    Apr 19 2022
    Cactus Green '99 A4 Avant TQMS Project, '00 E39 BMW 540i6
    New England
    Uhh, why not just get another VQ? They're quite plentiful.
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    You can easily make it a standalone but I would highly suggest making it with ME7 as its more versatile and easier to adapt to whatever config you got.
    Its still a huge job though if you dont know how to wire , and tune it yourself. Trust me.
    Veteran Member Three Rings QuattroBucc's Avatar
    Mar 06 2020
    B5A4 1.8TQ g25-660, MK4 GLI K04
    Santa cruz, CA
    Does somebody sell an adapter to mate to your transmission? i think a 2.8 turbo or 2.7t would fit in engine bay/motor mounts a lot better since it already comes with a wide angle v6 and youd still have that v6 sound
