Results 1 to 18 of 18
    Senior Member Two Rings reardoma's Avatar
    Oct 18 2020
    NC/DC USA
    Cool WTB: IE tuning for DP setup + PowerLink Cable ...... APR Ultracharger
    Looking to source Christmas presents for a bit cheaper if possible. Currently APR DP2 flashed at Stage 2.
    Was going to do APR Stage 2+ Ultra but i don't think it's for sale anymore? thoughts?
    Looking to switch over to IE tune which would require the cable. Here's a link to the product. I assume there's a transferable method given a fee?
    Also looking to upgrade to the APR Ultracharger Throttle Body Upgrade
    Always looking for new 102mm AWE tips for the touring exhaust.
    Let me know if you're aware of any deals or have access to a used one, cheers!
    2015 Moonlight Blue 6MT PP+ -034 stage2+ & constantly modded
    Apr 20 2011
    Hackettstown, NJ
    I don't have anything but the cable can be used across multiple accounts without a fee. As long as it hasn't reached it's registration limit which I think is 5 cars
    2009 Brilliant Black A4 Avant Prestige 2010 S4 Prestige 6MT Swapped - SOLD
    2012 Nogaro Blue A4 Avant Prestige
    2009 Condor Gray A6 Avant Prestige - On daily duty. 240k miles and counting.
    2018 Glacier White RS3 Unitronic Stg 2 ECU / TCU
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    What's the reason for the switch to IE from APR?
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by mahhdd View Post
    ie has more modern options like test pipe file, and ethanol.
    outside of that, APR FTW
    Nov 08 2020
    Atlanta, GA
    Was asking reardoma, we've chatted before.
    Oct 18 2020
    NC/DC USA
    hey buddy! great to hear from you, pretty sure i owe you a beer or 5 still!
    honestly no good reason other than the ability to easily flash back and forth, have been wanting to try another since APR is all I've ever run. Since we last spoke i relocated to DC and so I've kept the car garaged in NC and have been recently taking it back and forth for weekend trips/scenic drives, but thought it would be cool to have the ability to flash to stock or flash a silly crackle to see if i can give my father a heart attack (parents garage in NC). I'll be taking it in over the next month for the 75k maintenance, getting new wheels/tires, and will order a CR15 front strut brace and APR ultracharger for garage noodling over the holidays.
    and back at ya, why have you stuck to 034 stage1 with your sepang beauty?
    Oct 18 2020
    NC/DC USA
    Quote Originally Posted by rand0mher0 View Post
    Cable is discounted for BF and is running around $130 but i wasn't sure about the fee/# of uses, so appreciate the insight.
    Oct 18 2020
    NC/DC USA
    bump so i can go cyber monday savings if nothing available here.
    Oct 18 2020
    NC/DC USA
    bump to the top because i don't even think i can purchase APR stage 2+ ultra ECU upgrade anymore?
    Mar 31 2008
    eS-4
    CAL*SO
    you can find ie/034 cables for $100 all the time
    as far as TB, just get the cheapest setup you can find. a few folks sell 80mm tb kits on the facebook pages.
    you can mix/match parts so dont worry about that.
    Oct 18 2020
    NC/DC USA
    - - - Updated - - -
    Quote Originally Posted by Fresh.S4 View Post
    now i'm confused, i was referring to the software tune for stage 2+ APR....
    Mar 31 2008
    eS-4
    CAL*SO
    I'm confused too haha
    You say you have apr but you want an ie cable?
    Oct 18 2020
    NC/DC USA
    I was thinking of going the IE route (no longer) because I haven't been able to find the next stage for my APR tune. I'm running APR stage 2 currently, looking to flash stage 2 ultra. If I'm mistaken and this can be done (preferably remotely) then awesome.
    Not going IE anymore as they don't have anything past stage 2, so it appears looks like i'll be going the 034 stage 2+ route , particularly because they offer the 25% discount when switching tunes.
    Nov 08 2020
    Atlanta, GA
    Quote Originally Posted by reardoma View Post
    A few things
    1) 034 has a 30 day trial, no questions asked return period
    2) Since you're 6MT - When you flash over, you're going to want to pay attention to 1st gear at low speeds - it's jerky AF due to their enhanced, remapped pedal. It was "unlivable" level jerky, and I'm surprised no one else complained about it until me.
    3) I reported this issue and worked with 034 on feeedback to help them develop the "throttle smoothing file". On my car it's called the Beta 7.02 file. I asked for a 3rd set of revisions; but, they said they didn't think any more refinements were necessary. I will say it's a huge improvement over their normal files. It's very livable, and the low speed jerky/bucking/heavy engine break feel in 1st gear is a lottttt less common. It does still occur; but, it's mainly at a specific miles and if you're in the range of 0-20% throttle. I think the speeds are like 6mph and 12mph.
    4) To get this file, all you have to do is email [email protected] and request the specific file you need and octane and that it needs to be the throttle mapping file.
    Mar 31 2008
    eS-4
    CAL*SO
    you can buy apr file a la carte. its $150 but you'd have to flash somewhere at a dealer
    IE has same file options as 034, stage1,2,dp,TB, test pipes, ethanol.
    im 6mt that swapped from apr to 034 and have ZERO pedal problems lol.... something else was making your car jumpy and they had to mod the file. that says its not the file. ive never seen any complaints about 034 files other than when folks were blowing engines up because of meth
    034 is 25% off for switching so the total comes to like $600. which is a PERFECT buy in price for what you get!
    Nov 08 2020
    Atlanta, GA
    Wrong.
    Other people report the same.
    I made a video where all I've done is flash between OEM and 034, and it only occurs on 034's tune.
    Also flashed between OEM to EPL on the same and the issue didn't exist.
    034 wouldn't make a smooth throttle mapped tune if an issue didn't exist. And it certainly wouldn't have solved my issue if the problem wasn't real. They also verified their shop car experienced issues as well.
    It could be box code related; but, it's unlikely.
    Mar 31 2008
    eS-4
    CAL*SO
    maybe. your car is also much newer than mine.
    Jan 22 2017
    Telford pa
    I got cts turbo test pipe for sale brand new in box
