Results 1 to 10 of 10
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    3.0t misfire under high rpm HELP!
    Sorry forclong post but i want to lay it all out there.
    Car is on 034 stage 2+ superduper tb 91 oct file. apr coils with 10k miles and ngk oem plugs woth 5k miles gapped to .026. car had carbon cleaning, waterpump/ thermo stat and new intercooler brics as precation 6 months ago. 0 coolant loss
    3 weeks ago i replaced my hpfp with a new oem unit and at same time added 034 piston upgrade. car looked great in logs . rarely hiting 70% duty 0 codes. sent logs to 034 and they said looks perfect.
    2 weeks later installed 034 super duper tb and switched to the correct tune. log here https://datazap.me/u/f4m0u582090/goo...?log=0&data=45
    a week later went to do a draggy run and at the top of 3rd start of 4th i got a epc/ cel. pulled over instantly shut off car and checked for codes. CYL 1, CYL 3, CYL 4 misfire WTF. owned car for 3 years never 1 misfire.
    cleared code and did a log of issue happening.
    https://datazap.me/u/f4m0u582090/bad...?log=0&data=45
    Evrything seems ok i belive in the log above besides lean after the misfire unless im missing something.
    WHAT I HAVE TRIED:
    tried gapping plugs down to .024 and the samething happens with misfire but now just cyl 4 . swapped the coil from cyl 4 to 1 and still cyl 4 misfire......
    current log with plug gap at .024 (happens right around 7k rpm in log)
    https://datazap.me/u/f4m0u582090/7k-...?log=0&data=45
    what gets me is then next drive it may drive fine. such as this log this morning with 0 hicups.
    Then ride home back to misfire cyl 4.
    Veteran Member Three Rings prestige.phantom's Avatar
    Jul 16 2018
    Connecticut
    Have you checked your cats? This sounds exactly like what happened to me before my cats failed and blew my motor.
    2013 Audi A6 3.0T Prestige
    | Phantom Black Pearl | Nougat Brown interior | LED Headlights | Cold Weather PKG | 20" Sport PKG Wheels & 3 Spoke Heated Wheel | Fine Grain Ash Natural Inlays | Michelin Pilot Sport AS3+ Y | OEM "Rings" Puddle Lights |
    | AWE Touring Exhaust | JHM Non-Res DPs | Eibach Pro Kit & Bilstein B4 Sport Shocks | Eurocode Trans Mount | JBX Carrier | S8 Front Brakes w/ EBC Red Pads | 034 ECU 93 STG 1, TCU, Rear Swaybar, and Endlinks |
    IG: @prestige.phantom @ctautoart
    Aug 04 2014
    Gloucester MA USA
    i have relocated cats a few feet back from engine, with rear o2 wores extended and siting behind the aftermaket cats. id thonk id get a code for the rear o2 if they clogged
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by prestige.phantom View Post
    cats are rattleing when i knock on them. getting them removed in a little bit not taking chances there.
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    Quote Originally Posted by f4m0u5 View Post
    Yea man be careful clogged cats cost me my motor remember
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Veteran Member Three Rings Patrick Matte's Avatar
    Jun 12 2018
    old car's: Porsche 911 86 3.6 varioram plus G50, elephant racing track suspension, 996 turbo brakes
    Beloeil , Canada
    Tell me you did a TB adaptation when you installed the TB ?
    Fuel your car with premium fuel after a TB adaptation and i bet a cherry coke this problem will dissapear.
    Fuel is low quality during winter, dont forget that. For exemple here on Canada the 93 OCT contain 10% of Ethanol all summer! During winter i rarely see higher than 4% of Ethanol.
    So every winter i go back to 91 OCT file, if i dont do that, knock will occur. Also keep un mind the 034 tune is more TIMING oriented than my IE tune.
    Envoyé de mon iPhone en utilisant Audizine Forum
    -Audi A6 2012 3.0T-
    IE Stage 1 93 Oct- Melen TCU : 11.72
    IE Stage 2 dual E40 : 11.05
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Possible fuel injector problems?
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by ANMS4 View Post
    yes ofcourse! i had to gut them out but work good as heat shielded test pipes
    Quote Originally Posted by Patrick Matte View Post
    Yes did tb and also running 93 oct fuel on 034 91 oct file! ty though for help
    Quote Originally Posted by Valpo A7 View Post
    tht was one of my next checks but lucked out it was the cat broken up and rolling around inside clogging it sometimes
    Nov 27 2018
    Valparaiso, IN
    Alright so you think the broken cat was causing the misfire but why is it always cyl 4? I am saying don’t discount there is another issue. A cat shouldn’t randomly keep misfiring on the same cylinder.
    Aug 04 2014
    Gloucester MA USA
    not positive but if i remember the misfire detector isnt exact so it might have been just coincidence. the first time it happend it was cyl 1 3 and 4, even tho the cat was on bank 2 where cyl 4 5 6 is
    im thinking the cat blew because the small 2.25 diameter i used and the fact of 3.25 PR past summer with 110 degree days. i heard a change rattle sound few months back but it went away so i thought nothing of it
    We will see what happens i appreciate it and will definitely keep an eye on things. im religious with logging my car when ever i do a 1/8 run to try and beat old times ,so i have logs from various weeks and never see any issues till this happend
    Also thanks for the advice to check cats, you and roof rails in other thread were spot on!
    what confused me was the problem being intermittent but now looking at the cat i see why it was only sometimes and higher rpm where it could get lodged and clog the exit
