Results 1 to 24 of 24
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    cyl misfire help
    Sorry forclong post but i want to lay it all out there.
    Car is on 034 stage 2+ superduper tb 91 oct file. apr coils with 10k miles and ngk oem plugs woth 5k miles gapped to .026. car had carbon cleaning, waterpump/ thermo stat and new intercooler brics as precation 6 months ago. 0 coolant loss
    3 weeks ago i replaced my hpfp with a new oem unit and at same time added 034 piston upgrade. car looked great in logs . rarely hiting 70% duty 0 codes. sent logs to 034 and they said looks perfect.
    2 weeks later installed 034 super duper tb and switched to the correct tune. log here https://datazap.me/u/f4m0u582090/goo...?log=0&data=45
    a week later went to do a draggy run and at the top of 3rd start of 4th i got a epc/ cel. pulled over instantly shut off car and checked for codes. CYL 1, CYL 3, CYL 4 misfire WTF. owned car for 3 years never 1 misfire.
    cleared code and did a log of issue happening.
    https://datazap.me/u/f4m0u582090/bad...?log=0&data=45
    Evrything seems ok i belive in the log above besides lean after the misfire unless im missing something.
    WHAT I HAVE TRIED:
    tried gapping plugs down to .024 and the samething happens with misfire but now just cyl 4 . swapped the coil from cyl 4 to 1 and still cyl 4 misfire......
    current log with plug gap at .024 (happens right around 7k rpm in log)
    https://datazap.me/u/f4m0u582090/7k-...?log=0&data=45
    what gets me is then next drive it may drive fine. such as this log this morning with 0 hicups.
    Then ride home back to misfire cyl 4.
    Mar 31 2008
    eS-4
    CAL*SO
    spark plugs coilpacks injectors
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by Fresh.S4 View Post
    i understand its alot to read. but plugs are new, i even gapped lower now at .024.
    i also tried to swap coil packs from cyl 4 to a different cyl and stil got same cyl 4 misfire. (coils new/10k miles apr version)
    as far as injectors they dont leak ( fuel pressure rises after engine shuts off and doesnt drop pressure) But i gues this doesn't mean they are fireing correctly
    Mar 31 2008
    eS-4
    CAL*SO
    swap injectors around :) thats the best way. you'll be fine reusing the orings etc. your looking for the misfire to follow the injector.
    also watch your misfire counter at idle. mine was going off like crazy but car would drive normal around town/freeway. only at wot would i misfire too. turned out to be 2 of them going out, so i bought 6 new ones. dont fk with refurb or cleaning. get new.
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Quote Originally Posted by f4m0u5 View Post
    Do you by chance still have your cats. Your fueling is way off from bank to bank. I have never seen trims differ that much from bank to bank. Your injector duty cycle on injector #1 Bank 1 is 1 ms higher then injector #3 bank 2. Your boost is also pegging the request and I don't remember you mentioning a ported blower.
    Sent from my SHT-W09 using Audizine mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Apr 29 2018
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by RoofRails View Post
    not sure whats goin on there. wasnt doing it before tb tune
    as far as cats i have relocated cats a few feet back from engine, with rear o2 wires extended and siting behind the aftermaket cats. id think id get a code for the rear o2 if they clogged up . im running spacers (the cats i have arent strong enough to get rid of cel.from removing factory cats) i gues i wouldnt get a code if they broke up only if they clogged. but if they broke up i shouldt get misfire only if clogged
    Apr 29 2018
    pretty sure those trims are because the misfire just happend, not sure tho i will look i to it more
    You can go through the logs if you want and double check but those weird trims were in the 2 I opened and it wasn't just a single instance.
    Sent from my SM-S908U1 using Audizine Forum mobile app
    Aug 04 2014
    Gloucester MA USA
    you are correct. it wasnt doing that before not sure why all of a sudden, if you check my first log with the tb up top it wasnt doing this, then all of a sudden started to (funky short term and inj duty)
    Apr 29 2018
    Right , the secondary O2s you have in the remote cats are responsible for LTFT. Those look normal. The primary O2s are responsible for STFT which are out of wack. Maybe one of them is on the way out , maybe a injector is hosed up or maybe one of those cats has collapsed. I wouldn't count on getting a efficiency code for a failed cat that is clogged up especially when the secondary O2 is in a spacer.
    Aug 04 2014
    Gloucester MA USA
    i thought ltft are jsut the long term adjustments and the stft are on demand adjustments. rear o2s should only have to do with monitoring cat health?
    i orderd 2 new bosch o2 sensors ( mine have 120k miles on them) they will be here tomoro. im also going to try a dif plug on cyl 4.
    i also think i will remove the tb just for the fuck of it to make sure its nothing going on there at some point. But only 1 thing at a time then test.
    Aug 04 2014
    Gloucester MA USA
    after 10 min idle , 25 min of easily driving, had 1 misfire cyl 2, 1 for cyl 4, and 3 for cyl 5. Ill try some bg 44k. i try to use it once evry 6 months and its been 9 months since used last.
    034 also suggested doing another throttlebody alignment. but im pretty certain the tb would not cause 1 side to be that rich ( -up to 20% fuel in stft) while other sides closer to 0 or on the positive side.
    Apr 29 2018
    i orderd 2 new bosch o2 sensors ( mine have 120k miles on them) they will be here tomoro. im also going to try a dif plug on cyl 4. And some bg 44k. i try to use it once evry 6 months and its been 9 months since used last.
    The wide band is responsible for the bulk of the real time adjustments and the secondary O2s do the fine tuning. The strategy being to make long term adjustments to minimize the adjustments the Primary O2s make. That's what I found in my research. Thats the factory strategy anyway and based off of a few issues people have seen with failing secondary O2s and running catless without a Test pipe file I believe most of the OTS tuners retain that strategy.
    Sep 16 2020
    West Michigan
    So what you are telling me is that my car will run lean over time since I have gutted cats and no test pipe file?
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Apr 29 2018
    Quote Originally Posted by sepheroth86 View Post
    There was lots of talk about that before test pipe files became a thing. Whether it's lean or rich would probably depend on if you use spacers or not. Either way I don't think anyone ever proved that running spacers on test pipes on a catted file caused any long term damage. Maybe your MPG could be a little more dialed in but I'm thinking that's about the extent of it. Once you go WOT the LTFT get locked down and the Primary O2s take care of things. I don't think you have anything to worry about. If your concerned you could always run a few logs and see how things look.
    Aug 04 2014
    Gloucester MA USA
    cats are rattleing when i hit them. have appt to remove them today since they are under car its easy
    Apr 29 2018
    Let us know what you find out and if it turns out to be the cats either post your set up or a link to it so others can be on alert if they have a similar set up.
    Aug 04 2014
    Gloucester MA USA
    of course thanks. Nothing worse then finding some one with same issue and then them not finishing up the tread with what fixed their issue!
    currently running heat shielded gutted redstar cats up top, and thrn magnaflow 2.25 epa complient high flow cats (59955) after the flex pipes.
    I would replace the cats but not putting same parts in for $400 that mah have already failed.... and to buy gesi they are guna cost $1100 for epa complient cats.
    I really liked the sound exhaust was producing although lately seemed louder on start up and little more raspy on wot. maybe they have been slowly failing past month or so
    Apr 29 2018
    I Have Redstar Gutted cats to a pair of small canister type resonators to a set of GESI Non EPA cats. I got a EPC a few weeks ago and thought I smoked one but when I checked on them they looked like new. So far I'm happy with how they are holding up. They won't clean up the smell as much as the EPA cats do but they are much easier on the wallet.
    Model # 10025
    https://www.amazon.com/GESI-G-Sport-.../dp/B08842K8Z220220612_185635.jpg20220412_145225.jpg
    Aug 04 2014
    Gloucester MA USA
    i was thinkin of giving them a tey even tho bot epa complient. but was also nervous since my buddy blew his motor from gesi cats clogging(the expensive ones)
    Mar 31 2008
    eS-4
    CAL*SO
    if you have gutted cats, then its not a cat problem? no one mentioned a p0420
    if it was the sensor, you'd throw a code too i think.
    if your gonna replace yours, get another set of generic 2.5" 200 cell magnaflow cats. I am running them no problems.
    Aug 04 2014
    Gloucester MA USA
    problem ended up being 1 cat broke into a chunk that kept clogging the outlet
    ENGINE SAVED!
    Apr 29 2018
    ENGINE SAVED!
    Congratulations on catching it prior to hurting anything ! Just one more win for 034s logging tool.
    Aug 04 2014
    Gloucester MA USA
    thanks for help!
    As of now dnt have to worry about cats melting now. i will probably throw those gesi non epa cats when i can. already not digging the new rasp up top rpm or the smell lol
