    Established Member Two Rings SzeBen's Avatar
    Jan 28 2019
    Hungary
    Symphony I radio stuck in SAFE mode
    Hello guys, so I have a double DIN symphony radio and cant pass SAFE mode. I know the code, no need to call dealer.
    So I went to the menu where 1000 numbers appeared, then I removed battery. I guess this was considered an unsuccessful attempt, and I think the previous owner entered the wrong code once. After that I left on 12V (radio on bench) for a bit more than an hour but still cant get out from SAFE option.
    Does anybody knows what should be done in order to able to unlock it? When im turning it on, i see a number two for a sec. I uploaded a video about it here:
    https://drive.google.com/file/d/11Vyh0wF8oDwSuwVNFpdlTgvkuPMFDTQP/view?usp=drivesdk
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Have you tried leaving it in on the car? There may have to be power to not just switched or constant power but both.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    If you failed the SAFE attempts , there should be a number 2 or 2 || lines on the display somewhere, if so you need to leave the radio on for 1 hour then you can attempt to enter code again.
    Have you actually verified you had it on for 1 hour + on the bench though?
    Jan 28 2019
    Hungary
    Yes, i gave power for the constans 12v, and S contact (switched 12v), and ground. Left the radio on power for more than an hour. Btw I have two radio which doing it, both has a code.
    Nov 13 2009
    Do you come back to the unit and it’s powered off? I found that when I had a head unit on the bench that I had to keep touching a dial or button so it wouldn’t turn off. I had to do this for an hour until it came out of safe mode.
