Brembo GT big brake kit for all B8 2009-2016 A4, A5, S4, S5, Q5, SQ5, and RS4/RS5. Red, monobloc 6 piston calipers, pads, 380mm x 32mm 2-piece floating rotors, brackets, as well as Goodridge steel braided brake lines.
more info here: https://www.buybrakes.com/brembo-1m1...on-red-caliper
if you’re looking for high performance brakes while reducing corner weight as well as rotational mass, this is the best BBK for the Audi B8/B8.5 platform.
loaded stock B8 S4 brake caliper: 17.6 lbs.
stock B8 S4 345x30mm rotor weight: 23.5 lbs.
Brembo GT 6 pot monobloc caliper: 12.8 lbs. (4.8 lbs lighter)
Brembo GT 380x32mm rotor assy.: 18.8 lbs. (4.7 lbs. lighter)
rotors are 32mm new, and currently mic out to 31.64mm/31.69mm L/R. Brembo suggests replacing the rotor rings at 30mm, so these have more than 75% life remaining (assume pads are similar).
rotors and some hardware show some rust from sitting, one calipers has an unfortunate chip in the face, other than these these look as new.
$3250 shipped & insured OBO.
