Results 1 to 8 of 8
    Junior Member Two Rings jarrodblake's Avatar
    Jan 26 2015
    1983 911 RSR backdate long hood, 1970 chevy C30, 1991 MX5, 1997 wrangler unlimited. 1989 moto 4
    Patriot, IN
    05 B6 1.8t fans on on start up
    I have a 05 B6 1.8t. The fans turn on on start up and stay on. I have replaced the sensor on the lower hose and on the back of the head with audi vw oe sensors from ecs tunning. The check engine light code is p2181. is there a way I can trouble shoot what part has failed? A little more info I drive 15 minuets to work, by the time I get there then temp gauge is at 1/4 or a little under. The ecu temp is at 176.
    Jan 24 2010
    Paramus,NJ USA
    Founds like a bad FCM or issue with control wire going to the ecm.
    Ziddy Autowerks
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Your code indicates a "Performance Malfunction In The Cooling System" This occurs when the ECM isn't seeing the temperatures it expects to see. This code does not indicate any type of electrical component failure.
    The default position for this code is to run the fans all the time. The ECM knows something is wrong so it acts to protect the engine.
    I suspect your problem is being caused by a sticking thermostat. for more detail read posts 14 and 22 in this thread: Clicky click®️
    Jan 24 2010
    Paramus,NJ USA
    Cooling system performance is always a bad thermostat.
    Ziddy Autowerks
    Active Member One Ring Keef sweat's Avatar
    Sep 28 2021
    Salt Lake City
    It’s the fuse that goes to the central comforts/ the climate control fuse.
    When the fuse pops, it throws fans on on startup.
    Veteran Member Three Rings Puddin Tane's Avatar
    Jun 22 2020
    Athens, GA
    Quote Originally Posted by Keef sweat View Post
    Fuse #24 in the main fuse panel, far left of dash (uppermost and left-most of the larger size fuses), should be 20 amp in an '05. If blown, check for standing water or moisture under the floor of the passenger side footwell (where the climate control module (CCM) is located), which would in turn point to blockage of the battery tray drains or blocked or leaking sunroof drains. May need to replace CCM.
    Jan 24 2010
    Paramus,NJ USA
    Thermostat is your issue. Change thermostat and all will be good.
    Ziddy Autowerks
    Senior Member Two Rings canonball's Avatar
    Apr 20 2011
    Tacoma, WA
    Any updates on this? I'm having a similar issue (along with some other issues ), curious to know what you got figured out, op.
