Results 1 to 6 of 6
    Sep 04 2009
    Brand New - USP Stainless Steel Clutch Line (5 or 6 Speed)
    I purchased this for an aftermarket clutch I never installed it.
    Asking $35 and includes free USPS priority shipping.
    https://www.uspmotorsports.com/USP-M...keep_https=yes
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    I just installed a UPS Stainless on my car. It's probably the best mod for a 6MT car. You can actually feel a consistent engagement point now.
    Job will take you about 4 hours though.
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
    Mar 31 2008
    eS-4
    CAL*SO
    does tranny need to be moved or anything?
    Nov 08 2020
    Atlanta, GA
    Quote Originally Posted by Fresh.S4 View Post
    No. Check these instructions from ECS - https://www.ecstuning.com/b-ecs-part...017626ecs01~a/
    NOTE: Make sure when you pull the stock line out of the master the seal comes with it. It's very common it stays in master and clogs up the new line.
    Senior Member Three Rings 2008s4's Avatar
    Oct 28 2016
    Central, CT
    I installed mine from ECS (they’re all the same) and followed the directions from ECS as well. Totally agree it was a great upgrade. It took me a little longer than 4 hours, but that’s because it was my first time ever diving into a B8 platform. I actually had to go back in and remove an o-ring I left in the master cylinder and I got to in about 1/3 of the time I originally took. 100% recommend the upgrade and at $45 it’s a no brainer.
    2008 S4 Brilliant Red (sold) | 2008 RS4 Daytona Grey (sold)
    2008 A4 2.0 Avant (sold) | 2016 S4 Misano Red (sold)
    2014 MB E63s Wagon Eurocharged | 2015 Q5 3.0 034 Stg 1
    Sep 04 2009
    Price drop from $45 to $35 w/free shipping!
