Results 1 to 7 of 7
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Map Controlled Thermostat started failing P0597
    Started getting P0597 codes for the map controlled thermostat open circuit, and it would come back after clearing and set the MIL.
    I am at 76k miles.
    7036 - Thermostat for Mapped Engine Cooling (F265)
    P0597 00 [172] - Open Circuit
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 5
    Mileage: 121784 km
    Date: 2022.10.27
    Time: 17:08:49
    Engine RPM: 4430.00 /min
    Normed load value: 57.3 %
    Vehicle speed: 64 km/h
    Coolant temperature: 93 °C
    Intake air temperature: 56 °C
    Ambient air pressure: 830 mbar
    Voltage terminal 30: 14.041 V
    Unlearning counter according OBD: 40
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    $1400 to replace. Part is $360. (If I had the inclination or the time the part is only $200 online.)
    New superseded part from the original is 079-121-115-BL
    I miss my '68 Firebird...about 10 bucks and fifteen minutes to replace the thermostat. Ha.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Quote Originally Posted by gk1 View Post
    I am at 76k miles.
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Mileage: 121784 km
    Date: 2022.10.27
    Time: 17:08:49
    I was quoted that to replace mine too, ended up doing it myself. bought a brand new updated oem one for $280. it was the latest revision i believed it ended in "BL" and comes with the gasket and housing
    theres some useful info here if you want to tackle it. or have a mechanic do it. The quote is high because the official procedure involves pulling the whole front end and what not. But that is not necessary to reach the thermostat for replacement
    https://www.audizine.com/forum/showt...ge-with-dealer
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Aug 06 2014
    NJ->CO
    Yeah, I appreciate it and kudo for DIY.
    I just wasn't that ambitious and especially after just tackling the driver's side spark plugs nightmare.
    Hopefully they did the vacuum fill too because I don't have that tool either.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Jun 28 2019
    California
    Oh sorry I misunderstood, didn’t know you had them do it already. All good either way, it’s water under the bridge. But yeah I didn’t vaccuum fill mine, I just bled the system after filling and it worked fine. I’ve done it like that on a C7 several times. Just for future reference if you ever do need to fill the coolant system and don’t have a vacuum filler
    IG:@stolens6
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Audibellybutton View Post
    Yep I had them do it since I can also get the rental from them for a few days while it is down and they fixed a loose secondary air hose.
    I had always though since the turbo coolant lines are close or maybe above the coolant reservoir it was a challenge to get the air out of the top of the system and is why they do the vacuum fill but it is good to know it is unnecessary for future reference.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Jun 28 2019
    California
    Yeah I think the vaccuum fill is more important if you have stock hx with no bleed port. The engine cooling system is pretty standard to bleed, but I also have the ability to manually bleed my Merc HX through the bleed port and the hx supposedly self bleeding too so that might be a better choice to vaccuum fill if you're on stock HX.
    Its sad to say but you also don't know if the dealership vaccuum bled your system unless you check your heater and watch your IAT's and coolant temps. We'll hope they did vacuum fill it properly though since they're supposed to lol
    IG:@stolens6
    Dec 14 2017
    If it's the thermostat on the side of the water pump assembly no need for service position. If it is the map controlled thermostat at the front of the engine, ain't way you're getting that out without putting it in service position.
