Results 1 to 18 of 18
    Senior Member Three Rings Diesel S5's Avatar
    Nov 28 2017
    PA
    Tires for OEM 20” black optics wheels…
    Can we move up to a 275 to get a little more sidewall without any issues…?
    Want to get a set of all seasons but not liking the idea of the 30 ratio on the 265…
    What’s the biggest we can run without causing any mechanical issues…?
    Senior Member Two Rings AccordingToAlex's Avatar
    Oct 04 2019
    SF Bay Area
    Yes you can
    Sent from my GM1917 using Audizine Forum mobile app
    Senior Member Three Rings CurvesAhead's Avatar
    Feb 07 2020
    Earth
    275/30/20 vs. 265/30/20 has the former gain 1/10 of an inch in sidewall height, not very much.
    2019 Audi S5 Prestige
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by Diesel S5 View Post
    Are the wheels 8.5" or 9" width? Keep in mind also that a wider tire doesn't mean a wider contact patch if the wheel is too narrow. The sidewalls will get pulled in to fit the narrow wheel and will cause the tread to bow. Ultimately, the center of the tire will wear faster than the edges, on top of the fact that you will have a smaller actual contact patch. I have an RS5 with the OEM set up of 275 on 9" wheels and I still feel 9" is too narrow for a 275 to optimize the contact patch. My vote for you is to stay with a 255. On an 8.5" or 9" wheel, it will ultimately yield the better contact patch and sidewall geometry. 275 will be optimal on a 9.5 or 10" wheel, and 285 on a 10" wheel. This is a perfect example of "just because you can, doesn't mean you should".
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RSQ8 Performance
    Nov 28 2017
    PA
    Quote Originally Posted by VVG View Post
    The OEM wheels are 9”… The stock Conti sidewalls are too stretched and looks terrible plus seems it’s going to put the wheel at more risk…
    From my understanding switching to the Michelin AS in a 265/30 will eliminate the stretch look but going to the 275/30 would also give me a little more sidewall…
    Feb 07 2020
    Earth
    Here's a tire chart:
    Dec 01 2011
    yes 275/30 will be just fine, that's the stock RS5 size (on 20x9 wheels also) and wont have any fitment issues at all on the S5 (shouldve been stock S5 size too IMO). correct you'll get better sidewall protection, i see no reason not to get them. the stock 265 do look more stretched because they are summers and contis, but still i'd go for 275 anyway.
    i'm actually running 275/35/20 on the stock BO wheels, not planning to lower the car so i have no rubbing issues, fitment is good, left rear just kind of grazes the back of the fender liner so you have to flex the liner out of the way a bit but it's not a big deal. otherwise i like these, i went a size up because of NYC roads here, feels much more comfortable and i'm alot more confident driving around now without worrying about bent wheels all the time.
    IG @theshawon
    Mar 14 2008
    MA
    What is the stock tire size? 255/30 or 255/35?
    Feb 07 2020
    Earth
    I do my stretching exercise every morning and so do my Continentals 265/30R20 on 20X9 Rotors.
    Oct 04 2019
    SF Bay Area
    Quote Originally Posted by CurvesAhead View Post
    my friend's dad bitches about those tires too on his S5 every time he sees my RS5 rotors with the 275s
    Nov 28 2017
    PA
    265/30
    Mar 14 2008
    MA
    Years ago, I had posted on some other car forum how a 255 tire of one brand was physically wider than a 275 of another. Really weird of how and why this happens, but it does. I don't remember the specifics but I had even posted pics.
    Feb 07 2020
    Earth
    Quote Originally Posted by AccordingToAlex View Post
    I agree, 275/30/20 would be a much better sized tire.
    Feb 07 2020
    Earth
    The OEM Continental 5P Sport Contact 265/30 runs narrow according to many that have used this tire, so I know exactly what you mean. It also is only good for 9 to 15k miles from those same users.
    Dec 01 2011
    yeah certain tires do run narrower. continentals in general run a bit narrower, those stock 20 ones are summers and even narrower than the avg contis too.
    to upgrade those 265/30 stocks, i'd recommend 275/30 for a good oem fit, or if you want to go slightly thicker for better comfort and protection, on up to 9" wide wheels, i would recommend 255/35/20, it's a great fit and adds a bit of cushion, and no fitment issues if you aren't lowered.
    IG @theshawon
    Veteran Member Three Rings Andy_FL's Avatar
    Mar 01 2004
    South Florida
    Yes this exactly. Here's a 265/30 Bridgestone for example - clearly a much more square sidewall than the 265 Conti on this rim. Any of you guys with 275s who can post a picture, it'd be helpful.
    Oct 04 2019
    SF Bay Area
    Stock RS5 Pirellis 275/30Screenshot_20221119-143755.jpg
    Mar 01 2004
    South Florida
    Nice, thanks for posting that.
