Planning on making it work along with the HVAC fan, sadly couldn't find any pinout on the internet, maybe someone has it.
About the radio, I want to connect an AUX to it, there's pins for it, pretty easy to wire it up and if I recall correctly I need to program the radio? Probably same with Bluetooth. Last time I redid the wiring the cluster lost connection with the radio, I put in the code and it was back in touch, started showing me radio info but after staying overnight it doesn't show it anymore, but communicates with it cuz of the correct time and lighting. I'm guessing I need the gateway module maybe, then it'll show the info all the time, and yes I checked the menu, radio info is on.
Also maybe someone has the hazards button/esp turn off button pinouts?
Last thing I was wondering is how does the handbrake sensor work?
Help appreciated!
