Results 1 to 9 of 9
    Junior Member Two Rings
    Feb 15 2022
    04 A4 Avant, 04 S4 Avant, 03 A4 Avant, 04 A4 Sedan
    Washington
    How much would you pay for a 6MT B6 S4 Avant that needs timing done?
    150k miles, overall pretty clean besides interior wear and a minor blemish on bumper.
    Aftermarket wheels, lowered.
    Trying to find the average price so I am not overpaying.
    Thank you!
    Veteran Member Three Rings Atomic Avant's Avatar
    Jul 11 2016
    2005 S4 Avant, 2016 Q5
    Ontario, Canada
    With the info you provided, 3k at most.
    Apr 07 2022
    2004 B6 S4
    Eugene Oregon
    It's a tough call considering the mileage. There's quite a few "wear items" that could rack up the bill. Assuming everything else is in good shape, and you can do the timing chains yourself, I would probably go up to 5k. You have to really want the car, prepare for an engine over-haul, and pray the cylinder walls aren't damaged. Honestly with piston rings being such a common failure at that mileage, and you can't drive it because of the chains, probably best to shoot for 2-3k. The seller can't ask for much since the car can't be driven, and timing chain service (if paying a shop) exceeds the value of the car.
    At 150k you could expect certain things. Other than normal wear items, these cars have particular problems to address. Upper control arm bushings, front and side engine mounts, driveshaft center support is probably sagging, Slave cylinder boot could be melted (saw it on my b6 with 195k and the other with 80k, damn precats), dual mass flywheel loose (again, both cars), piston rings, valve stem seals, oil cooler seals, a/c compressor, aux radiators, pcv, intake runner, etc.
    Some of these things can be expected, if there aren't service records provided, you could subtract the costs of expected repairs from that 5k. Then do a thorough inspection and subtract those things.
    Obviously many things can be done over time, but you should factor in expected repairs. I'd give my left lung for a clean avant, so the little things wouldn't bother me, but you should be concerned for the engine mileage. Good luck!
    Apr 19 2022
    Cactus Green '99 A4 Avant TQMS Project, '00 E39 BMW 540i6
    New England
    A lot of "While you're in there" services you'll want to do, like the clutch, RMS, etc. So it can rack up quite a parts cost.
    Senior Member Two Rings bennyc767's Avatar
    Mar 31 2009
    An Old Avant
    The Big Sky
    It's hard to say without looking at the car, I bought one recently and have been following them when they come up for sale on here. Really depends on the condition and maintenance history. The cost of the service is, for the price of the parts around $2k for the AMTuned ultimate kit and of course factor in all the "while you're in there" as has been said. If you don't want to do the service a forum member on here will do the service for $2k. Honestly these cars can sell for $10-15k depending on a lot of other things so if the car is nice I could see spending quite a bit more than what others have suggested. If you really want a B6/B7 6MT Avant, they're not getting any easier to come by.
    Aug 09 2012
    Bay Area
    Sedan nothing above $4,000 - $5000.
    Avant nothing above $7000
    Assuming its MT and in decent condition (including no roof sag on the avant)
    Jan 23 2014
    '13 Touareg TDI - '08 RS4 Mug/Ti
    Derby City
    lol. 2-3k.
    You're likely looking at a car that needs anywhere between 10-20k of parts and labor, depending on what you see as a necessity beyond a basic chain job (while you're there, seals, clutch, upgraded parts, etc...)
    Established Member Two Rings mnvwaudiguy's Avatar
    Nov 24 2014
    Two Audi A4 Avant 3.2Q Titanium, 2004 A4 USP Avant 2.7TQM, 2005 S4 Avant, 2018 Toyota Sienna AWD
    Apple Valley, MN
    Quote Originally Posted by BallnchainB6 View Post
    Nailed it.
    I had all of those issues except piston rings on a 70K mile S4 when I did the timing belt in 2019. I did not address the cylinder heads, choosing to just live with it.
    Total bill was near 12K (not counting control arms, which were done separately).
    The 4.2 S4 is an awesome car, but a maintenance nightmare. If you are willing to do the work yourself and the car is not your only car, there is a high reward factor. If you have to pay someone else or you only have one car, don't even bother.
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Quote Originally Posted by mnvwaudiguy View Post
    100% accurate
    This is my situation, and for that reason I really love the car. But it’s pretty much this scenario that is required for that love, because the car doesn’t always love you back. It’s like dating a princess. Or a bridezilla. But I’ve learned a whole lot working on the car myself, whenever I’m able.
    I'm still listening for that rattle!
    If it rattles, it's because I baby it.
    B7 S4 25Quattro
