Car is 2013 A6 3.0T with stock sports suspension. Just hit 71,000 miles.
My car is starting to shift like crap. Both up and downshifting. I am feeling every shift. Nothing is too crazy but I feel them all, even when it shifts from 7th to 8th. And EVERY press of the gas even a little results in a 1 gear downshift which I feel more that I ever used to feel. The engine braking from 7 to 5 and 5 to 3 is ridiculously jerky.
With that said, I am very frustrated with this beautiful hunk of metal right now.
There an adaptation procedure that I found in VCDS for a 7 speed trans. It can be found here --- http://wiki.ross-tech.com/wiki/index...rbox_(DSG/0B5)
I know that's not my trans and I don't see anything in the Ross Tech wiki like this for the 8 speed trans. Is there something for the 8 speed out there?
I don't know exactly what this is used for or it is allows the car to reset the shift patterns to begin the "relearn" process.
There is a procedure I can do in my wife's Mercedes with just the ignition switch and gas pedal that resets the trans shift points and it makes the car shift soooo much smoother......for a few months.
Is there something like that we can do using VCDS, or otherwise? I have seen similar youtube videos where people are doing a similar procedure for Audis where they are holding down the gas pedal to the floor, etc but I'm skeptical. Again, it absolutely works on my wife's Mercedes so I'm going to try it later today just for giggles.
I find it hard to believe anything is wrong with my trans at 71k miles and I would hate to throw money at a trans oil change and changing all the other diff and transaxle fluids for it to not make any improvement.
Any thoughts?
Thanks.
