Results 1 to 11 of 11
    Aug 25 2022
    MA
    Blurry front Grill Camera 2015 A7
    Hello,
    The front grill camera on my '15 A7 is coming up very blurry, cant really see whats in front. Is the camera bad?
    I tried cleaning it but still blurry.
    Aug 25 2022
    MA
    Here is how the camera comes out.
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Is there dirt between the camera and the exterior lens? If I pressure wash mine, I can flood out all the crap and when it dries it looks fine. I don't pressure wash it just to clean it, but when I am cleaning the car, it happens.
    Aug 25 2022
    MA
    Quote Originally Posted by WatchMeSpend View Post
    I cant see any dirt. So you're saying you pressure wash it to remove the dirt? I try cleaning it, but just the outside lens.
    Mar 19 2019
    Toronto/Ontario
    Quote Originally Posted by MikeB12D View Post
    I am guessing the exterior part of the camera lens is made from sapphire to take stones without chipping. If I were to drool mud down the hood and let it cascade over the camera lens with no pressure and let it dry and then wipe the lens, it will be blurry. Same with salty or soapy water. If I pressure wash the camera area and flood it with clean water, the image is clear.
    So, it's just a theory but I'm 90 percent sure the exterior of the camera is like a protective contact lens on your eye, and the dirt is between the contact lens and your eye.
    Aug 25 2022
    MA
    Mar 19 2019
    Toronto/Ontario
    So now that we pried the eyeball out, what are we doing with it?
    Aug 25 2022
    MA
    Took it apart, and cleaned, but still blurry/cloudy
    Senior Member Two Rings Akakios's Avatar
    Feb 05 2022
    2014 Audi S7 | 2018 Audi S4
    DE
    The lens needs to be buffed out with a polish first just to be certain it's not too far gone. It looks like it had major UV damage or there is bubbles under the lens. You could use a heat gun/blow drier to low heat to see if it's water but I would try a plastic polish first.
    Deutsche Auto Garage - Website // YouTube // Instagram
    2014 Audi S7 (Audi Exclusive Interior)
    2018 Audi S4
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Did the image become blurry gradually or suddenly? The rear has both sharp and blurry areas; I assume that means the problem is with the optics rather than the image processor.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Aug 25 2022
    MA
    Quote Originally Posted by Alabama View Post
    It been blurry since i got the car. The rear is fine.
    Sent from my SM-S908U1 using Audizine Forum mobile app
