A buddy and myself installed a RS5 style grille on my 19 Sportback yesterday. I am having two issues. One is with the parking sensors being right up against the crash bar. I thought I had read about shorter sensors being available but I have been unable to locate them via searching. I removed the foam that was on the bar and spray painted the bar. It would have never fit with the foam on.
The second issue is the camera mount. I knew it was an issue when I saw it out of the box. I thought I had preemptively solved it by locating a 3d print file for a mount that pointed more like the OEM orientation. It seems like the file was for a RS4 grille as there was no chance of it fitting. I was able to use the mount with the grille but it is pointed way too high.
Does anyone have information proper replacements for either or both items? Many thanks in advance.
