Results 1 to 18 of 18
    Established Member Two Rings Benji16's Avatar
    Apr 27 2020
    Eustis
    Need help locating part numbers
    What are the vacuum hoses that connect to the purge valve and the water pump? Can seem them anywhere onlineScreenshot_20221112-155415_OfferUp.jpg
    Jul 16 2018
    Atlanta
    Which engine code is this? CCBA, CGXC, or CTUB?
    Apr 27 2020
    Eustis
    CTUB
    Jul 16 2018
    Atlanta
    https://audi.7zap.com/en/usa/audi+a4.../1/133-133052/
    Looks like line (13) with check valve (14), solenoid (6), and line (15) are the path components to the coolant pump.
    Apr 27 2020
    Eustis
    Quote Originally Posted by Smac770 View Post
    You sir are a gift sent from god lol thank you eo much i searched sooooo much and not even the dealer parts department knew what i was talking about.
    Apr 27 2020
    Eustis
    hmm thats wierd i put 06E133714H and 06E 133 714 G and i get the same hose. but i need 2
    Apr 27 2020
    Eustis
    Apr 27 2020
    Eustis
    Jul 16 2018
    Atlanta
    13 includes both hose sections that it points to, with the check valve 14 in the middle. From your last picture, you have the half that connected to the T at the end of hose 1 and the check valve 14. But you can't get just the section between the check valve and the solenoid 6. Audi doesn't package it that way. Unless you pick up a used one where someone is just selling that bit.
    https://parts.audiusa.com/p/64124274/06E133714G.html
    Appears 06E 133 714 G is now 06E 133 714 T.
    https://www.ecstuning.com/b-genuine-...se/06e133714t/
    https://parts.audiusa.com/p/71903421/06E133714H.html
    And 06E 133 714 H is now 06E 133 714 AA.
    https://www.ecstuning.com/b-genuine-...e/06e133714aa/
    The half of T that you need and AA might look similar, but I suspect they are bent differently.
    Apr 27 2020
    Eustis
    Right but the links you provided are the same hose just in different links looks like a need 2 of the hoses.what i need now is number #15 on the diagram.
    Jul 16 2018
    Atlanta
    ? I'm not sure what you're looking at. They are clearly not the same product. One is G (now T), the hose 13, long, two hose sections and a check valve, as a single assembly. One is H (now AA), the hose 15. That 15 looks like half of 13 is not relevant. There is no option from Audi to get just the left end of 13, even if that's all you need. But you could get it from a junk yard that way.
    Apr 27 2020
    Eustis
    So yu are telling me this hose is #number 15? It looks much smaller then the diagram thats what confussing me.Screenshot_20221114-003647_Chrome.jpg
    Jul 16 2018
    Atlanta
    I'm only saying the parts catalog says hose 15 is 06E 133 714 H. And parts.audiusa.com says that has been superseded by 06E 133 714 AA. And that's the picture ECS has for 06E 133 714 AA. I have no reason to doubt it. From your original picture, it's not far from the solenoid to the port on the coolant pump. https://www.audizine.com/forum/showt...1#post14010689
    The parts catalog drawings are usually pretty good, and the part identifier is not in () (meaning the image is not a direct representation of that part number), but there's only so much 2D can convey.
    Apr 27 2020
    Eustis
    Yes i'm going to call my local dealer to see what they can find out you have been very helpful man.
    Apr 27 2020
    Eustis
    Ok i got it figured out with the dealer you were right on part numbers. $132 for both hoses ordered them.
    Apr 27 2020
    Eustis
    Hey man stupid question if i put a piece of hose that goes to the purge valve to the water pump wouldn't it so the same thing? Or will that not work?
    Jul 16 2018
    Atlanta
    I'm not sure what you're asking. Can you use any old vacuum hose from the solenoid to the water pump and would that work? I imagine so, as long as the hose isn't some soft tube that collapses closed under vacuum. Not sure what you mean by purge valve, as that implies N80 EVAP purge valve to me.
    Apr 27 2020
    Eustis
    Sorry not purge valve i mean the solenoid that has the 2 nipples for the water pump and yes i just dont see spending $75 if i can use a hose the wont colapse. If that works i will go that route. I did get the other hose though
