Car is a B6 V6 6MT quattro avant, 235K miles
So I was out of town for two weeks. Car was sitting in my driveway the entire time. I come home and go to start my car and I get nothing. I check and my crappy bluetooth OBD reader (different from my ross tech) was still plugged in, so im thinking that might have drained the battery.
I check the battery with a meter and its dead. I try my trickle charger, and the battery is too dead for that to work. I get my friends 15-amp charger/starter, hook it up and I get some electrical response after about an hour. I get the usual clicking of a very low battery. I switch the charger to starter mode; turn the key and she started right up.
I disconnect the starter/charger, close the hood and go inside for a few minutes to grab some stuff, I hear the revs go up and down a little bit (which isn't too out of whack since I have a hole in the exhaust, not like it redlined or something, but maybe swung from 500-900 instead of sitting at 750) ....then I hear NOTHING. I go back outside, and the car is off with the key in the run position still. I go to try the key and I get zero electrical response again, try the hazards, and nothing.
I go to pop the hood and put my meter on the battery, and there is very light smoke of some sort in the engine bay. Like electrical fire type smoke (im a volunteer firefighter). I instinctually go to disconnect the batter and the battery cables are WARM to the touch. I pull the battery completely, take it out, multimeter shows some life in the battery and so I put it on my trickle charger overnight. overnight it charges fine, I test it the meter and get good voltage. I connect the battery with a set of jumper cables instead of fighting to get it back in its spot, I turn the key, and get nothing. I hit the hazards, I get nothing. when i go to disconnect the jumper cables, they are WARM too. The smoke didn't come from the driver's side a pillar where the ECU/computer is, but from around and under the motor. after a day or so I could still smell the smoke and it was strongest at the air manifold, but also I was limited to where I could put my nose.
thoughts?
