2007 A4 2.0 TFSI Quattro
P0171, P0507. + Multiple misfires
Idles high but tachometer stays around 800-1000 at times.
Elm Scanner states idle is around 2000 - 3500 RPMs.
Idle can get up to 5000 RPMs when in neutral. Calms down when in Park but fluctuates between 1700 and 800 RPMs.
Morning start up seemingly normal. Heats up cat converters then back down to 730-760 RPMs.
After warming up and during the day, the idle and start up is unpredictable.
Replaced N80, gas cap 0 ring, PCV valve, MAF sensor. Pulled the plugs and coil packs. No oil found on either.
Replaced the cam follower 10,000 miles ago.
Oil cap comes off normal when engine is running.
Sprayed for leaks and listened for air hiss.
Wiggled connections on sensors and elsewhere with no idle change.
Transmission can shift hard at times in D.
Has progressed to not wanting to stay running after start.
Pulled the MAF connection couple of days ago, and now running on default specs.
Cleared the codes a couple of times. Always the same ones come back.
Do these 2.0 TFSI's all have the manifold flaps?
Am I correct in the Idle control module is by the throttle body?
I haven't checked the accordion metal hose from the valve cover and don't know if there is a way to.
Hope I am posting on the right forum?
Any help appreciated. Thanks.
