Originally Posted by
chadwebb04
So are halogen projector lens and HID/LED projector lens different? I know the HID needs a ballast but the kits come with them. It is a simple plug and play with the kits. In my younger years I had a few sets on a mustang. (Terrible idea in reflector housings)
I could be wrong but the projector bowls are different as the reflecting pattern is different between halogen and hid. I’m not sure what kit you are referring to. I’m assuming they are single xenon and you will need to retain your high beam bulbs. Unless the kit is made for it, the housings are different between the typical hid bulbs that Audi uses and the conventional H7 or H11 bulbs. If it’s an aftermarket kit, it may be designed for the halogen housing.
Sent from my iPad using
Audizine
