Results 1 to 11 of 11
    Sep 28 2022
    Minnesota
    245/35/19 Square vs Staggered Set Up
    Please help me pick out my new set of tires! After doing some research on here, it sounds like the consensus for a square set up on the 8Y is 245/35/19. However, would it make more sense to go with the OEM sized tires but with more sidewall on the front, for example, 260/35/19 in the front of 245/35/19 in the back. I'm getting all-seasons to drive in the winter but I'm not planning to drive the car when there's snow on the ground (got a daily with winter tires for that!). My assumption is that the wider tires up front will offer better acceleration versus the squared set up?
    Thinking about going with Yokohoma Advan Sport A/S+.
    May 08 2020
    2015 Golf R DSG, 2015 Golf TDI 6-speed.
    Purcellville VA
    As I've discussed here in this Forum, I am running 245/40/18 tires on Neuspeed RSe10 18x8.5 wheels, now at 42,217 miles of which 30,396 miles have been fast country back road runs 10am-2pm as weather permits on Tues, Weds and Thurs only, when very few if any other vehicles are on these roads.
    This configuration is currently on our 2019 Audi RS 3 and was also which I have been running on several other vehicles of ours (2015 Golf R DSG, E28 BMW) and has proven to be a very good configuration. I've been running these country back roads for the past 49 years, when we moved from Santa Monica (our fast Pacific Coast Highway days) to Northern Virginia in 1973, where I worked at the now defunct Xerox International Training Center, owned and operated by someone else now.
    Some pictures are posted in MY PHOTO GALARY if you're interested.
    Rod RS-3
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by rs3_guy View Post
    Just be careful you dont change your overall tire diameter by more than ~3% from stock, 265/30 to 256/35 is an increase of ~4.1% so i wouldnt do that. 245/35 square will work pretty good.
    https://www.tacomaworld.com/tirecalc...0r19-265-35r19
    The reason the car is reverse staggered from factory is to decrease understeer, not for acceleration, there maybe some very marginal gains from the wider front tire but doubt you would notice on street tires.
    Stage 1 more than you RS3
    Oct 08 2021
    Uxbridge MA
    Might be an unpopular opinion but if you’re worried about acceleration performance, all seasons aren’t the answer, regardless of width.
    I’m personally running a 26” diameter tire (255/40/18) and use a 225/40/19 on stock wheels for snow tires.
    I thoroughly enjoy the taller side wall
    Sep 28 2022
    Minnesota
    Quote Originally Posted by o1turbo30v View Post
    Thank you, this confirms what I suspected!
    Sep 28 2022
    Minnesota
    Quote Originally Posted by b1aZe View Post
    Do you have an 8Y? Are you saying you got 255/40/18 for summer tires and 225/40/19 for snow tires?
    Oct 08 2021
    Uxbridge MA
    8V and yes, 255/40/18 for summer and 225/40/19 for snows. On different wheels obviously
    Junior Member Two Rings
    Aug 23 2009
    2008 A4 Avant S line/Titanium pkg
    Gresham,Oregon
    On my 19,running 245/35R 19 squared on 8.5” square stock wheels for summer.For my winter wheels,running Nuespeed RSe10 18X8.5 with 225/40R 18 LM101 Blizzaks.Had the Blizzaks left over from my 2 S3”s & still had good tread on them.Better to have smaller & thinner for winter driving!
    Mar 04 2010
    95.5 Audi S6 Track car 2010 S4 with mods 2006 Audi A4 2.0T S line w/ mods, 1974 Alfa Romeo 2000 GTV
    NY/NY
    If you are going to have a dedicated set of summer wheels and tires, do what I have done. I run 265/35/18 square Michelin Sport Cup2 for Spring, Summer, and Fall on my RS3. I also use them as a wet weather tire at the track. They have an immense amount of dry weather grip when warmed up. I have a 2008 A4 as a dedicated Winter driving school, foul cold weather, and dog's car, that I run on Nokian Winter studded tires.
    2019 Ara Blue RS3, APR Stage 3, DSG tune, UM Haldex tune, TTE700, APR 4" turbo & throttle inlet, rear carbon tube, pendulum mount & dogbone insert, Tyrolsport Front Deadset Kit & Harness bar, Superpro LCA bushings, CSF radiator, JDY Performance oil pan, APR FMIC, Race Downpipe, catted Mid Pipes, Milltek exhaust, Wavetrac LSD F&R, KW Clubsport 4 coilovers, Neuspeed tubular sway bars and 350mm rear rotor kit, AP Racing CP9660 BBK, RSE11R 18X9 45mm offset wheels, 265/35 Michelin Pilot Cup 2 squared
    May 21 2014
    United States
    Can you elaborate on why you never want to change your overall tire diameter by more then 3%? Is this a milage reading issue or will it cause issue with the AWD system/need to be reprogrammed for a different size tire?
    Feb 06 2012
    Allentown, PA
    Quote Originally Posted by bbowers825 View Post
    It’s your Speedo accuracy, abs, and awd systems. Someone dug up a spec from Audi and that was the recommendation.
