Results 1 to 3 of 3
Thread: Sunroof Drains
    Junior Member Two Rings
    Apr 21 2016
    Western NC
    Sunroof Drains
    Anyone have any info on the drain locations and keeping them unclogged? I've tried a few searches but come up empty for the B9 platform.
    Having issues with clogs/leaks in previous vehicles, I'm hoping to stay proactive on the Q5. I went behind the rear wheels and found a drain on the passenger side, but there was no drain to be found in the same area on the driver's side. Haven't checked the front yet, currently raining outside.
    I did see this earlier for the B8, but they don't show the rear driver's side, will confirm if the fronts are the same when I have a chance - https://www.audizine.com/forum/showt...rain-hole-exit
    Feb 01 2017
    NoVA
    Rear drains are underneath the wheel well covers.
    If you have air suspension, you can go off-road mode and you don’t even need to remove the wheels to remove the cover and get access to the drains.
    No luck finding the inlet at the rear of the sunroof, but cleaning from outlet worked for me. Then using a squirt bottle in the sunroof track to flush it all out.
    Mine were slow/clogged from street work and neighbors’ yard services blowing dust etc.
    Nathan
    ____________________________
    '19 SQ5
    '64 356 SC 1720
    '73 914 2.8 6-cyl conversion in progress
    ‘02 S6 Avant - gone to a new owner to live up to it’s potential as a 6-speed
    RIP (tree) ‘99.5 A4 2.8 Quattro Tip - GIAC engine and tip chip, Stage 3 MAF mod, A8 front rotors
    Feb 20 2016
    Greenville SC
    Gently sliding string trimmer line down the tube helps clear them also
