Results 1 to 9 of 9
    Active Member One Ring BoostedDesigns's Avatar
    Oct 28 2014
    San Diego, Ca.
    Start stop usually not working
    Hey everyone, another question for you. My start stop has only ever worked once or twice since i purchased my S6 about 3 months ago. i get the icon of the start stop with a cross through it 99% of every time i drive it. I checked errors with ODBElven and i don't see anything that stands out. Any thoughts?
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Weak battery will disable it.
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    If there is too many electrical accessories on, it won't work. Also like Valpo says. Mine works mostly with minimum heat/cooling and when the engine is hot. Turn on heated seats and steering wheel and you can forget it.
    Mar 29 2014
    Hampshire, UK
    The ECU analyses a number of different parameters, any one of which will override the auto start/stop system:
    1. Engine temperature
    2. Air Conditioning use
    3. Load on the electrical system (lights/MMI/heater/wipers etc.)
    4. Outside ambient temperature
    5. Battery condition
    All of these are continually monitored, and any one can override the start/stop function, the reason being it needs to maintain a minimum battery voltage in order to instantly restart the car in the start/stop scenario. This is also why, in a long stop scenario, the car will restart even though you’ve not indicated that’s you’re about to move off.
    First suggestion would be to have the battery tested at a shop that knows how to test the battery, and go from there!
    John
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Aug 08 2008
    2017 Q5
    Houston, TX
    Don’t use the AC and it works fine. If it’s on, it doesn’t turn on for me. Try that and see. Also, be sure you are firmly pressing on the break.
    __________________________________________________ ____________________________
    2016 Aud S7 - Massaging Seats are pretty neat
    2013 VW Passat TDI - Black - sold
    2015 S4 Prestige - DSG - Mythos Black Metallic 2003 Civic EX 5spd - Gone
    2010 F-150 Lariat Super Crew - Gone 1988 Toyota Supra N/A 5spd - Gone
    2008 A4 2.0T 6spd - Gone 1999 Civic EX auto - Gone
    UTSA Alumnus - #BIRDSUP #WBC #GETROWDY
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    I had mine turned off completely. I cannot se any benefit of doing this for the individual owner.
    2016 S6 - sport - optx- atlas - AE nardo
    Mar 19 2019
    Toronto/Ontario
    Mine is turned off. I have turned it on while waiting for someone in a parking lot. The car was cycling on and off to maintain temps without constantly idling .
    Nov 27 2018
    Valparaiso, IN
    Quote Originally Posted by esemes View Post
    It saves about 5 cents of gas per minute that the engine does not idle. Agree not much each time but city stop and go traffic will add up. Even knowing that I still turn the system off.
    Mar 19 2019
    Toronto/Ontario
    When I got my car, I tried to use it but it cuts the engine at stop signs. Give it some throttle to go after you stop and it cuts the engine and you look like you fell asleep at the wheel. Stop and go highway traffic, maybe. I've just turned it off and forgot about it the majority of the time.
