I have attached few picture to show what's happening:
This seems to be ok.
Passenger side head. As you can see, the chain guide that shattered into many pieces is missing there
Driver's head. No issue there
https://live.staticflickr.com/65535/...d030a188_c.jpg
The one that known to fail fell out too when I open the back cover
https://live.staticflickr.com/65535/...f84f81cb_c.jpg
This is what fell out
https://live.staticflickr.com/65535/...f9a699b1_c.jpg
Again, I cannot rotate the crank right now. It hits something which I'm not sure what it is hitting and therefore, I cannot get it into service mode or TDC? BTW, how do you link up the motor to be TDC or in service mode? Is it just by where the cams you can install the cam locking tool? What position the crank suppose to be in?
I have on order the timing chain kit from FCP Euro. I was thinking of just simply put in the 2 broken guide from the new ones I'm getting and see if I can rotate the motor and set it to TDC? What suggestion would you guy give so I can get this motor ready? I bought it used off someone and they said it was rotating but I guess I'll never know for sure. Someone suggest me to take the cams and head off and inspect the cylinder bore. What should I do?
Thank you.
