Results 1 to 8 of 8
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Tranmission oil cooler leak
    My friend is an idiot he jacked up the trans cooler to replace the trans mount and i realized now its leaking. My question is now i need a trans cooler but when i remove it will a lot of atf fluid will gush out of there? Or just a little bit? Will i need to ad ATF fluid aftrr replacing ?
    Ivan
    Aug 19 2013
    Miami
    I got my answer / thread
    Ivan
    Sep 16 2020
    West Michigan
    Quote Originally Posted by dalmation53 View Post
    Might be helpful for people in the future to know what you did to rectify the issue.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Disconnect at the hoses and carefully lower it down to a catch pan to contain the mess. Put new back in place then pump fluid into the unit through 1 of the hoses. Once all back together bring up to temp and check fluid level to top it off. All together you will probably need about 1/2 quart of ZF ATF fluid.
    At least that is what is did when I pulled the engine / trans to do the timing chains.
    Aug 19 2013
    Miami
    Thank you for your reply man did to ucb fluid came out or not that much?
    Ivan
    Nov 27 2018
    Valparaiso, IN
    I really did not lose much fluid from the transmission or open lines when I removed it. But I knew that I was going to lose the volume of the cooler which is why I filled it before hand. Once I got it back attached and up to temp I did not lose any fluid from the fill plug which is why I topped it off at the fill plug.
    Aug 19 2013
    Miami
    Well i barely lost any fluid tbh it was quite easy to replace.
    Ivan
