Results 1 to 8 of 8
    Junior Member Two Rings
    Sep 10 2022
    Australia
    “Do not exceed max engine speed of 4,000 rpm“
    4,000 rpm“ ETC i think i forgot
    What does this mean? It keeps happening when i exceed 4,000 rpm everytime i put it on sports mode or manual shift. What can i do to stop this from keep popping up?
    Audi a4 2011 1.8tfsi
    Oct 24 2018
    Germany
    Did you do a google search for that exact phrase? I copied and pasted it into google and the hits came back to this very forum and others.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Quote Originally Posted by Cin. View Post
    oil pressure. Sorry...
    B6 S4, B8 A4, 8P A3, and something, something.
    Feb 23 2019
    Pickerington, Ohio USA
    Quote Originally Posted by RPMtech147 View Post
    Yep. Used to happen on my old engine. Oil pressure fault is what ODIS said every time.
    Apr 05 2014
    Texas
    I will add; the only time I've seen this fault is when I installed a used motor in a Q5. The oil pan was dented and pushed into the oil-pump-pick-up(say that 5 times fast).
    At low engine speed it was fine, but the restriction of the pan pressed against the pick-up tube caused a loss of pressure @ high RPM. Replaced the oil pan and GTG.
    These engine are notorious for low pressure @ low rpm. The low pressure at high RPM is rare...from my experience
    What I'm saying is ...crawl under the car and make sure there isn't a big dent in your oil pan.
    Sep 10 2022
    Australia
    Yep i just solved the problem. One of the oil pressure switch connertor/header something idk what to call it was not connected was just hanging lucking didn’t got tangled into the radiator fan. No more warning when i push the engine to 4,000rpm.
    Apr 05 2014
    Texas
    I assumed you checked the basics before posting. Good fix!
    Sep 10 2022
    Australia
    Yep i did. Thank you
