Results 1 to 8 of 8
Thread: Gauges
    Feb 23 2022
    Montenegro
    Gauges
    In near future I want to buy boost,oil pressure and air to fuel ratio gauges.I heard that mechanical gauges are faster and more accurate but I want gauges to look good in my interior..Any reccomendations?
    Послато са SM-G960F помоћу Тапатока
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    I would never buy a mechanical oil gauge, for the fact if the fittings arent tight or wear, you will run into leaks. Boost is ran from a plastic vacuum line and fuel ratio is electrical.
    1998.5 A4 1.8TQM My Build
    Feb 23 2022
    Montenegro
    Quote Originally Posted by xdewaynex View Post
    Brand suggestion to look for?
    Established Member Two Rings HibiscusB5_A4's Avatar
    Sep 27 2020
    2001 B5 A4 1.8TQM
    Redlands/Fairfield CA
    I haven't had any issues with my AEM for afr. I use the ECS tuning boost gauge kit and that works great too, the boost gauge is going on a year, and the AFR about 4-5 months.
    Feb 23 2022
    Montenegro
    Quote Originally Posted by HibiscusB5_A4 View Post
    Oil pressure?
    Apr 19 2022
    Cactus Green '99 A4 Avant TQMS Project, '00 E39 BMW 540i6
    New England
    Quote Originally Posted by bajo_01 View Post
    Oil pressure?
    Is it in any way possible to tap into the oil pressure sensor on the engine? Because if I remember correctly you have a 98 1.8T, which should have an oil pressure sender?
    Feb 23 2022
    Montenegro
    Quote Originally Posted by cactus_cars View Post
    Idk man,currently car is not at home he got an engine overhaul after 24 years,and its getting hybrid turbo capable of 250hp.I have oil pressure sensor which now I am pretty sure its dead because of oil pressure warning 2 times and the oil pickup line is clean af..
    Established Member Two Rings silvera4q's Avatar
    Dec 20 2007
    2001 Silver A4 1.8T
    Cincinnati, Ohio
    The VDO gauges match the best in my opinion. You will need an oil pressure sender to mount on top of the oil cooler
    2001 A4 1.8t quattro, Mods:GIAC-X tuned, Short shifter, apr snub, custom CAI ,cat back 2.5" ss exhaust, custom carbon fiber interior parts,VDO Boost and Oil Pressure Gauges, yellow fogs
