Results 1 to 15 of 15
    Jul 31 2021
    Carrollton
    For those that swapped their own DP
    If I'm on the factory DP going to an aftermarket DP will I be able to reuse the bolts and nuts or will I need new ones ? I thought the bolt was basically welded to the factory DP and cannot be used on an aftermarket DP
    Thx in advance
    Jan 22 2005
    Central CT
    I have cts hfc i needed to use new hardware
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Factory DP has non removable pressed studs. New DP will come with nuts and bolts
    '18 S4 Prestige; all packages
    Jul 31 2021
    Carrollton
    Quote Originally Posted by SHCKR View Post
    Thought so
    Only problem is the used one I bought. No hardware :/
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    Not sure if it's the same for everyone else, but my oem cat had 2 non removable studs and the 3rd one was on the up pipes. Made for a nice guide pin putting the new one in.
    19' Glacier S4 Black Optics
    Feb 10 2020
    Frisco/Texas
    Quote Originally Posted by haveyoumetjeff View Post
    Thought so
    Just go to Lowe’s and pick up the hardware. M10 I believe
    Jan 08 2018
    24 RS5, 24 A6 Allroad
    Twin Cities, MN
    Thought so
    You need to pick up four m8 x 30mm bolts. They have them in two packs at Home Depot for a couple dollars. The factory nuts are m8.
    Senior Member Two Rings brandonbanana's Avatar
    Jul 14 2018
    2010 Lexus IS 250, 2023 Audi Q8, 2016 Audi S7
    Oahu, Hawaii
    Quote Originally Posted by Diokhan View Post
    Thank god for this thread. I have the same issue as OP. I was just messaging CTS for a set of replacement bolts and gaskets and it came out to about $42.28 and I was about to pay for it till I saw this thread. Thank you
    Feb 10 2020
    Frisco/Texas
    This man is correct. M8 is the size you need. I went with stainless from Lowe’s, but I’m sure the packs form HD would be fine too.
    Jan 03 2019
    '19 Subaru Ascent
    NC
    You can look here for an install guide:
    https://www.audizine.com/forum/showt...php?p=14465082
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    check ebay, there’s some people selling m8 nuts that take 10mm sockets. it makes installing 100x easier, since you can’t fit a 13mm socket in there.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 20 2020
    New Jersey
    Quote Originally Posted by Gunnarrrrr View Post
    Exhaust Manifold nuts are definitely clutch for this install - https://www.amazon.com/Exhaust-Manif...16829174&psc=1
    Or Reduced flange nut etc same thing but def get the 10mm head
    Mar 25 2015
    Placer County
    For some it might seem like overkill, but I always drop the whole exhaust for this job. it takes another 15-20 minutes but makes it a breeze. if you unbolt the exhaust’s downpipes from their hangers you can pull the cat pipe out the top with the downpipes attached to get all those 6 bolts effortlessly, then slide the whole thing back down. You’ll need to remove the chassis support brace of course.
    Also so you dont spend forever fishing for torque specs, I compiled them all here with diagrams for clarification:
    https://www.audizine.com/forum/showthread.php?t=962404
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Feb 04 2019
    Georgia
    Do you, by chance, have any pictures of that method?
    Seems pretty nice...
    Do you unbolt the hangers and take off the exhaust clamps of the 2 pipes going down to the mid muffler as well? How much of those pipes can come through the top?
    Sent from my SM-S908U using Audizine Forum mobile app
    Mar 25 2015
    Placer County
    Quote Originally Posted by QuickHandCam View Post
    Yep, those clamps come off then I unbolt and remove the lower downpipe hangers. But its only a few bolts to drop all the exhaust hangers. I just remove the rear hangers, downpipe hangers, and cross brace & hanger, and slide it back and off the downpipes. Then I unbolt the downpipes from the transmission and they’re free. I can get the cat pipe out a few more inches this way and easily access all 6 bolts. Also using an engine hoist to wrap a chain around the cat pipe helps a lot for supporting it and pulling it out. I then wrap a chain around the back of the cat pipe to pull it into the turbo so I dont need a second pair of hands to line it up while I secure the clamp. just make sure you have something soft in between the hoist and the front bumper.
    Someones gonna make fun of me for what seems like a lot of effort, but jokes on you I dont have scratches allover my forearms
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
