Results 1 to 15 of 15
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Comment on Snow Tires for C7 (255/40/19)
    All,
    I live near Chicago and typically run winter tires on my cars as I much prefer summer tires in the summer and all seasons feel like a compromise all the time. I previously had Pirelli Sottozero 3. I'm not generally a fan of Pirelli, but I admit those were pretty good tires for (1) our optional sizes, (2) cold weather, (3) a bit of water, slush or limited snow fall. That said, after 4 seasons I switched my 255/40/19 winter tires to Vredstein Wintrac Pro. After about 200 miles (just this past few days) in 50* temps, I can say they're generally quiet and comfortable for snow tires. And, they feel reasonably competent on dry and wet pavement. My summer tiers for reference are Michelin Ps4s.
    No comments about, snow, slush or ice, but they're rated pretty well by tirerack and their customers. I got my tires early this season as I expected supply issues, and there aren't too many snow tire options in 255/40/19. Bought the same tires for our Civic. And, we have previously used Continentals (Viking 7) without incident.
    I hope this helps anyone looking for a "performance-ish" winter tire. If you're in the snowy mountains - from what I've read - this tire is NOT for you. But for the flat land around Chicago, or similar, it might be an option worth considering.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    I've heard good things about the Vredsteins, good to hear the additional feedback. This will be my first year running dedicated winter tires, I got an OEM set from someone with an S6 that are unfortunately the pizza cutter 235 section AO Conti Winter Contacts. Not really looking forward to going from the meaty 265 PS4S to these things but I am excited to see a little snow to see how it does.
    We've had a bit of a heat wave the last couple weeks but I think I'll bite the bullet and swap to my winter set this weekend.
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    I run all seasons on all my cars in the Chicagoland area without any major problems. Now if I was in an area that got more snow then yeah I would likely look at dedicated snow tires. Chicago is very good at having the major streets and highways cleared within 24 - 48 hours but I cannot speak about the side streets. While I have a 2.5 car garage I just don't have the space to store a set of tires for each vehicle in my home fleet.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by Valpo A7 View Post
    Yeah only reason I went the dedicated setup was because I wanted good summer tires, not so much the concern with winter tires. I'm in a heavily populated area with a 5 mile commute, even in heavy storms there's basically never more than a couple inches of snow on the road. Grew up driving 2wd pickup trucks in the snow so anything is better than that lol
    Nov 27 2018
    Valparaiso, IN
    I never ran the summer tires even in my Mustang days, always had all seasons, but I did have a second car at the time so I could park the Mustang in the winter in my garage. High power rear wheel drive was certainly fun except in the snow.
    Chicago gets 30 - 40 inches of snow but clears the roads very well. Having the quattro system helps a great amount for winter, I felt better driving the A7 in the snow than I did our old AWD Jeep Patriot. Have to see how the new Wrangler is in the snow, should be very good.
    For those that are thinking of getting snows, if you have the room to store a second set and want summer and winter tires then go for it. Summer tires in the winter are NOT something to test fate with. Even with clear roads the grip from a summer tire on dry but cold roadways is not good.
    Sep 16 2020
    West Michigan
    My Audi was ok in the snow with Pirelli all seasons.
    It is a totally different beast in the snow with real winter tires.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Established Member Two Rings McNeil's Avatar
    Aug 26 2011
    C7.5 A6 Competition
    I also purchased a set of Vredstein WintracPro’s this season after my Continental’s needed replacement. Will report back on performance once there is some snow on the ground
    Dec 02 2021
    Colorado
    I ran vikings on mine last winter on 18" wheels. I live in the mountains in CO and go over passes at least once a week. They did great.
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    i was really considering the Vredstein for all seasons, like you said they rate rather well so the brand really seems like it's getting on par with the rest of the upper end brands. As i have yet to buy tires (trying to make the ones last as long as i can due to costs) the only reason I'm not buying them is from all the testing I've seen/read and from a few people on here who got them rolling resistance is not good on them at all and for an all season kind of important with fuel prices lol.
    i figured snow tires they would be decent at for sure as they have been around longer than people think.
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    IF all seasons: DWS06+ or Michelin AS4, none other compare.
    Prior: '16 A7 3.0T Prestige, '16 S7 Prestige, ‘17 S8 Plus, '18 Porsche Panamera Turbo S - E Hybrid
    CURRENT: '23 Nardo Gray RS5, Carbon Black Optics, '18 Q7 Prestige
    My S8 modified exhaust: https://www.audizine.com/forum/showt...Muffler-Delete
    Sep 12 2022
    Syracuse, NY
    I got a steal of a deal for some used Nokian Hakkapeliitta r3 tires for my 2014 A7. Almost new tread and I got them for $500. Not bad since they are like the #1 rated studless and go for like $1100 in this size. Probably will finally get them mounted next week. I travel from upstate NY to VT in the middle of snow storms for skiing, so I'm excited to see how the quattro and these tires perform. Coming from an AWD T6 Volvo S60 which had goodyear winter tires last year. They were just okay.
    Sent from my SM-G998U using Tapatalk
    Oct 18 2017
    NW Philly
    I've driven with All-Seasons on a myriad of cars in my time between New England and the Mid Atlantic. Never had an issue in winter.
    I wintered a 2000 Trans Am 6-speed on bf Goodrich KDWSs....it did surprisingly well!!
    Sep 16 2020
    West Michigan
    Quote Originally Posted by Spitfire007 View Post
    I'm sure all the people with snow tires that were stuck behind you were thrilled to be there.😆
    Dec 02 2021
    Colorado
    DWS 06+ are my "summer" tires. I love them but they aren't in even the same ballpark of a snow tire when it comes to snow. Probably better than most AS tires but that's not saying much!
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by Bike_Pilot View Post
    If I didn’t enjoy summer tires so much, I’d probably seriously consider the DWS or Michelin AS3.
