Results 1 to 8 of 8
    Jul 22 2019
    Houston
    Intake Heat Sheild
    Does anyone know if this is an off the shelf heat shield and whether or not it would work with the SRM long intake?
    TIA
    Sep 16 2020
    West Michigan
    Looks like an ECS Tuning badge on it.
    I have heard of other forum members using the recently released ECS 4.0t intake system with great results.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    Quote Originally Posted by sepheroth86 View Post
    ECS, correct. I have one installed here. a part of the Luft-Tecnik system
    2016 S6 - sport - optx- atlas - AE nardo
    Dec 16 2022
    Fort Walton Beach FL
    I’m curious as well. I’m hunting for a heat shield for the SRM intake system
    - - - Updated - - -
    I’m curious as well. I’m hunting for a heat shield for the SRM intake systemy
    Jul 22 2019
    Houston
    I've reached out to the owner of that car. He has the SRM long intake and purchased the ECS intake shield as a single item without the rest of the intake. As you can see he had to cut the SRM intake pipes and rotate them to fit into the openings of the heat shield.
    I've been back and forth on doing this to my SRM intake but just don't know if there would be much benefit at all. When the car is moving there's a lot of fresh air being forced into that area so the only time I see this having a benefit is taking off from a dig. Even then I don't think it's going to lower temps dramatically.
    Established Member Two Rings joejoe3's Avatar
    Nov 25 2020
    Calgary AB
    https://www.ecstuning.com/b-ecs-part...hoCBKsQAvD_BwE
    Woah comes with a cover now? That should help with the heat soak at a dig?
    2014 Audi S7
    GONE: 2014 A7 3.0T / S line / Moonlight Blue Metallic
    [ EPL Stage II (PR 3.04) | EPL TCU | CTS 192mm Crank Pulley w/ stock SC pulley | JHM Heat Exchanger | JHM Inlet Hose w/ aFe Power Dry S | Eurocode Drivetrain Inserts ]
    Mar 05 2023
    SC
    I would be absolutely shocked if the IATs post turbo were more than 1° lower with this. Compressing air creates heat, turbos are hot as hell already. Most people run these turbos way out of their efficiency range. A heat shield is only going to lighten your wallet.
    Established Member Two Rings caelric's Avatar
    Jun 10 2023
    Colorado Springs, CO
    Quote Originally Posted by HowlingMad View Post
    well, it would look good in the engine bay as well.
    but you're right, with turbos, what matters is the air temp after the IC/CC, not the air temp going through the intakes.
    but it would look good...
    2016 RS7 Performance - Prism Silver Crystal - Comfort/Bang & Olufsen - DS1 Stage Custom 1 w/ BTRes- TGK Intake - 034 Suspension/Transmission/Differential Inserts
