Results 1 to 3 of 3
Thread: P052A Code
    Nov 07 2022
    Chicago
    P052A Code
    Hi, i've had P052A lingering as an intermittent code for awhile, but today it finally turned into a CEL. The research i've done varies btwn camshaft position sensor to VVT actuator/solenoid. Anyone else have this? - Would appreciate some guidance!
    Cold Start "A" Camshaft Position Timing Over-Advanced.
    Nov 07 2022
    Chicago
    2016 Audi a3 2.0t Quattro
    I did google it but didn’t find much for the A3/8v. What did you find?
    Dec 25 2004
    Earth
    Quote Originally Posted by Throttle View Post
    What are you using to get this code?
    The A3 repair manual does not list P052A...
    The VW manual has it...
    https://www.vwvortex.com/threads/p00...valve.8404802/
    P052A Cold Start "A" Camshaft Position Timing Over-Advanced Bank 1
    Camshaft Adjustment Valve 1 - N205- ,
    Checking
    General Description
    The camshaft’s task is to operate the valves at the right time and
    in the right order to control the charge cycle. Camshaft adjustment
    using the Camshaft Adjustment Valve 1 - N205- varies the opening
    times of the valves to suit all operating conditions. This ensures
    ideal charge cycles within a wide range of engine speeds
    and loads. Fuel consumption and pollutant emissions are reduced,
    torque and smoothness increased. In engines with a
    double overhead camshaft the size and positioning of the valve
    opening overlap can be influenced, enhancing characteristics in
    full-load and part-load operation. In continuous camshaft adjustment,
    the adjustment is infinitely variable within specific parameters
    IGNITION: OFF.
    - DISCONNECT: Camshaft Adjustment Valve 1
    - N205- harness connector.
    - CHECK: Camshaft Adjustment Valve 1 - N205-
    component connector terminals 1 to 2 for resistance.
    - SPECIFIED VALUE: 5 to 20 Ω (at approx. 20°C)
    Was Value obtained?
    NO:
    -REPLACE: Camshaft Adjustment Valve 1 -
    If your going to DIY repair it there are electrical items to check...
    Or take it to a shop.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
