Results 1 to 10 of 10
    Sep 12 2021
    North Houston Texas
    Turbo inlet install question
    I'm trying to get the factory inlet off, and the front hose connector is a pain. I'm trying not to break it but what ever sensor that is is pulling out of the plastic coupling. What am I missing to take that off?
    Oct 13 2017
    Birmingham, AL
    This one? There are some clips at the bottom. I'm about to order an inlet too so I was looking at vids yesterday.
    https://youtu.be/wCwZHd_mbfY?t=414
    Like spacecase said, I have seen other people using that pick tool too.
    2018 S4: 034 Stage 1 ECU : S2 TCU : Wagner IC : Modded intake
    Oct 03 2020
    San Diego/CA/USA
    Quote Originally Posted by Speedster00 View Post
    The connector was very difficult for me, the tabs were at the bottom and it broke off. I had to replace the hose to the new PN with the better membrane so I just grabed a 90 degree pick tool, stuck it in and pulled it to where it wasn't fully caught on the lip and wiggled it out. It took me 30 minutes of trying to manhandle it and when I got my pick tool it took a minute. It didn't damage the connector at all, but it might damage the plastic a bit.
    Established Member Two Rings LifetimeAudi's Avatar
    Nov 30 2020
    Durham, NC
    If you push in while you're undoing the clip it makes it much easier to remove.
    Sep 12 2021
    North Houston Texas
    Quote Originally Posted by YoYo View Post
    Yes! That dang thing. I didn't realize there was a tab on the bottom. Worked it with a screwdriver. Thanks for the vid.
    Oct 13 2017
    Birmingham, AL
    Ya man... good luck
    What inlet did you purchase?
    Jul 09 2020
    New York
    That's only the first step of what is a painful install. Unfortunately it gets worse when trying to remove the screws that attach it to the turbo.
    Veteran Member Three Rings Andy_FL's Avatar
    Mar 01 2004
    South Florida
    Quote Originally Posted by Turbo6S4 View Post
    LOL right? He’ll be back to discuss “that bottom bolt” I’m sure.
    Oct 13 2017
    Birmingham, AL
    Ha.. I was going to mention that too. What tool did you guys use? Did you just rig something or used a particluar tool?
    Quote Originally Posted by Andy_FL View Post
    Jan 08 2018
    24 RS5, 24 A6 Allroad
    Twin Cities, MN
    I used something like this which made things easy:
    I thought disconnecting the front tube was way worse than the bottom bolt.
