Results 1 to 10 of 10
    Oct 03 2020
    San Diego/CA/USA
    Is adding a rear sway bar worth it?
    Back with my A3 a RSB was what I considered a top 10 mod for the platform as it really made the car handle better, reduced squat, and made it feel like it was on rails.
    I just purchased one as my last piece I wanted to add before my first track day with this car, but after doing more reading it seems like people are saying the sport suspension is fine (I have sport suspension and diff) and a RSB isn't really worth the money.
    For those that got one, is it worth it? Im not lowered yet, but I'd rather spend the money on something I would get more functional value for especially for the track.
    Feb 02 2021
    San Diego
    Absolutely yes yes yes yes yes. I've got everything done to my car you can get function wise, short of stage 3, and the sway bar is the most noticeable mod. Don't even wait for other replies lol just buy it
    Oct 03 2020
    San Diego/CA/USA
    Quote Originally Posted by Sebastian Tu View Post
    Good to know, already purchased and should be coming in tomorrow. thanks for the feedback. If you're ever down to hit up a track or drag event lmk! I'm going to streets of willow on the 10th of dec.
    Sep 12 2021
    North Houston Texas
    Huge difference. I put one on with stock sport suspension also and it helped a ton. Then it got even flatter when I put on EMD springs. Now I'm about to get a strutt tower brace
    Sep 28 2010
    NW NC / DE
    Very much worth it. Get the endlinks too.
    Jan 04 2009
    ne
    Is the thought that the rear bar is undersized from the factory and the aftermarket bar helps dial in neutral handling?
    Oct 03 2020
    San Diego/CA/USA
    Thanks all, guess we'll see how it feels once I install it
    I plan on getting both front and rear end-links once I get my coilovers. I think the stock end-links will be fine for now on stock ride height. Will see how the bar and stock endlinks fits on the stiffest setting and will probably end of buying adjustable endlinks if I don't like how it sits.
    Feb 02 2021
    San Diego
    Quote Originally Posted by spacecase View Post
    Oh I've always wanted to try a track day! That would be super cool
    Jul 09 2020
    New York
    Generally, a stiffer rear end would tend to bias the car towards oversteer. Virtually all production cars are tuned towards understeer for comfort and liability reasons. Going to a upgraded RSB would tend to make the car more neutral than Audi would feel comfortable with as a baseline set up.
    Oct 03 2020
    San Diego/CA/USA
    Ended up installing it today. Very happy with it so far and I would say worth the money. I don’t think you need the end links unless you lower as everything buttoned up well while the suspension was under load at the stiffest setting. I recommend getting the rear mount inserts and diff inserts to install them all in one go which is what I did as removal of the rsb is necessary/helpful to install the inserts.
