The 034Motorsport High Pressure Fuel Pump Piston Upgrade Kit for Audi 2.9T & 3.0T EA839 is erfinally here!
The 034Motorsport High Pressure Fuel Pump Piston Upgrade Kit is designed to be a drop-in replacement piston for the factory high pressure fuel pump for the 2.9T and 3.0T TFSI EA839 engines found in the B9/B9.5 Audi S4/S5/SQ5/RS5, C8 Audi A6/A7/S6/S7, and 4M.5 Audi Q7/Q8.
By upgrading the factory high pressure fuel pump with the 034Motorsport High Pressure Fuel Pump Piston Upgrade Kit, the factory fueling limits are raised by up to 37% in 2.9T or 3.0T EA839 engines. This increased flow allows the fuel system to meet the higher demands for ethanol, race gas, more pump gas, and pairs perfectly with all Dynamic+ ECU software that requires an upgraded High Pressure Fuel Pump!
FEATURES:
  • Yields up to 37% Flow Increase Over the Factory High Pressure Fuel Pump
  • Raises the Factory Fueling Limits Present in 2.9T and 3.0T Engines
  • Increased Flow to Meet the Demands of E85 Optimized Tunes and Turbo Upgrades
  • Required for Most Stage 1+, 2+, and Stage 3 Performance Software
  • Fuel Pump Internals Precision-Machined to Aerospace Tolerances
  • DLC Coated Piston and Cylinder for Reduced Friction and Increased Performance
  • Matched Piston and Cylinder for Absolute Precision
  • Relatively Easy Installation
WHAT’S INCLUDED:
  • 1x Pump Piston & Cylinder Set
Note: EA839 High Pressure Fuel Pump Tool is highly recommended for ease of installation
Check it out here!
